Quick MAP sensor question....
Old Jul 18, 2008 | 09:57 AM
champLSinteg's Avatar
Default Quick MAP sensor question....
I am swapping the motorola 2.5bar MAP sensor for a 4bar version. I am using S300 but the 4bar version is not an option in the MAP sensor list. I remember hearing that the Omni/Hondata 4bar MAP sensors use the motorola piece inside which would mean I can just select that option, right?
Old Jul 19, 2008 | 04:05 PM
Default Re: Quick MAP sensor question.... (champLSinteg)
One at a time now!
Old Jul 19, 2008 | 05:51 PM
mtber's Avatar
Yes, the omnipower 4 bar setting is the same as the hondata 4 bar map sensor uses the same settings
Old Jul 19, 2008 | 10:42 PM
Default Re: Quick MAP sensor question.... (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Yes, the omnipower 4 bar setting is the same as the hondata 4 bar map sensor uses the same settings </TD></TR></TABLE>
So I can use the omni/hondata sensor in S300 when using the Motorola 4bar MAP sensor?
Old Jul 19, 2008 | 11:21 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by champLSinteg &raquo;</TD></TR><TR><TD CLASS="quote">
So I can use the omni/hondata sensor in S300 when using the Motorola 4bar MAP sensor? </TD></TR></TABLE>
Correct. You can use any map sensor if you have the scalar/offset
beak
Jul 9, 2006 01:28 PM
lucidvtec
Jul 11, 2005 11:51 PM
b16 matt
Sep 21, 2004 07:00 AM
DubyaAye
Apr 28, 2004 10:22 PM
CiViC SiR
Jul 9, 2003 09:35 AM
