hondata 2 step vs msd 2 step?
Old Apr 22, 2006 | 04:38 PM
PTR1's Avatar
Default hondata 2 step vs msd 2 step?
anyone using hondata 2 step to build boost off the line? to my understanding the hondata cuts the fuel vs the msd which cut the ignition. i was wondering if it would be safe with the hondata?
Old Apr 22, 2006 | 04:59 PM
turbochargeb18c's Avatar
BANNED
Default Re: hondata 2 step vs msd 2 step? (sinceday1)
if you got the s300 itll allow you to built boost off the the line but not the s200...the msd will allow you to built boost also
Old Apr 22, 2006 | 06:08 PM
N20civicB18's Avatar
Default Re: hondata 2 step vs msd 2 step? (turbochargeb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbochargeb18c &raquo;</TD></TR><TR><TD CLASS="quote">if you got the s300 itll allow you to built boost off the the line but not the s200...the msd will allow you to built boost also </TD></TR></TABLE>
explain
Old Apr 22, 2006 | 06:45 PM
hybrixt's Avatar
Default Re: hondata 2 step vs msd 2 step? (N20civicB18)
S200 uses fuel cut for the 2step, while the S300 cuts ignition just like an msd.
fuel cut won't allow you to build boost.
Old Apr 22, 2006 | 07:13 PM
adseguy's Avatar
Default Re: hondata 2 step vs msd 2 step? (hybrixt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrixt &raquo;</TD></TR><TR><TD CLASS="quote">S200 uses fuel cut for the 2step, while the S300 cuts ignition just like an msd.
fuel cut won't allow you to build boost.</TD></TR></TABLE>
Neither will build boost really unless it's a smaller turbo. True boost off the line comes from an anti-lag type system where the ignition is extremely retarded and a lot of fuel is dumped. I know s300 has the anti-lag, but I think s200 doesn't
Old Apr 22, 2006 | 07:19 PM
BANNED
Default Re: hondata 2 step vs msd 2 step? (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">
explain</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">
Neither will build boost really unless it's a smaller turbo. True boost off the line comes from an anti-lag type system where the ignition is extremely retarded and a lot of fuel is dumped. I know s300 has the anti-lag, but I think s200 doesn't</TD></TR></TABLE>
Old Apr 22, 2006 | 08:11 PM
mrbsponge's Avatar
unless you use your Nitrous 1 or 2 option in romeditor to dump a butt load of fuel and pull timing when activated, just takes some time to fihure out, but no more complicated than AEM antilag
spoonhatchblack
Apr 16, 2008 12:26 PM
jdm2teg
Oct 23, 2006 10:02 PM
ELSpool
Jan 20, 2006 07:11 AM
Adriano
Jun 28, 2003 07:55 PM
98typer794
Apr 25, 2003 07:34 PM
