2 step in hondata.
Old Oct 19, 2006 | 08:51 PM
jdm2teg's Avatar
Default 2 step in hondata.
well guys i have a s300 hondata i just bought a 2step and i allready have msd. i want to know the differents between 2step on msd and one thats on handata. do i need to install 2step in my car or is it allready in with my s300. thanks
Old Oct 19, 2006 | 08:56 PM
THEDirtyDseriesWOOT's Avatar
the msd is ignition cut were the hondata is fuel cut ..u will make tons more boost off the line with the msd.. and it sounds cool as hell.. plus ull be fast and the furious shooting flames jejeejeje
Old Oct 19, 2006 | 09:41 PM
Dunc's Avatar
BCICAN
Default Re: (hitatree.at125mph)
^^^95% Correct. The S300 unit also has ignition cut. The S200 units only have fuel cut. Hasn't it been discussed that ignition cut is "better" than having fuel cut?
What exactly do you do to the tune when using the MSD system then? Like with timing/fuel?
Old Oct 20, 2006 | 04:12 PM
sc4dr's Avatar
Default Re: (AF-P Dunc)
I dont believe you do anything. Just wire it up.
Old Oct 22, 2006 | 09:27 AM
jdm2teg's Avatar
Default Re: (sc4dr)
i have s300 on my car right now and want to put the 2step in it. i also have msd so hord is it to hook it up to my car. do i do anything special to hook it up to my s300? and built boost.
Old Oct 22, 2006 | 09:43 AM
mike93eh2's Avatar
wait, where is the ignition cut 2 step in s300 ??? i dont see anythign about switching from fuel cut to ignnition cut
Old Oct 22, 2006 | 09:45 AM
ladysman's Avatar
Default Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">wait, where is the ignition cut 2 step in s300 ??? i dont see anythign about switching from fuel cut to ignnition cut</TD></TR></TABLE>
You can't.
It's either fuel only or Ignition and Fuel.
Old Oct 22, 2006 | 07:45 PM
jdm2teg's Avatar
Default Re: (ladysman)
from my understanding, s200 has the fuel cut and s300 has the ignition cut? let me know if i am wrong.
Old Oct 22, 2006 | 07:54 PM
mike93eh2's Avatar
man i dont know what to think of s300.. i dont think anyone knows what the real deal is with it..
Old Oct 22, 2006 | 08:48 PM
DRIVENRacing's Avatar
i run s300... i like and dislike it... as far as 2 step s300 has igniton cut, also has launch control and if you know how to set it up itll make way more boost than msd 2step.. ditch the msd, run s300.. gl
Old Oct 22, 2006 | 09:05 PM
mike93eh2's Avatar
how is it suppose to be set up "properly" ?
Old Oct 23, 2006 | 04:53 AM
Mikey3000's Avatar
Default Re: (adSPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adSPEED &raquo;</TD></TR><TR><TD CLASS="quote">i run s300... i like and dislike it... as far as 2 step s300 has igniton cut, also has launch control and if you know how to set it up itll make way more boost than msd 2step.. ditch the msd, run s300.. gl </TD></TR></TABLE>
can you show me something that confirms the S300 has ignition cut rev launch control? Hondata's website says it has fuel cut.
Old Oct 23, 2006 | 06:04 AM
96 GSR-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">
can you show me something that confirms the S300 has ignition cut rev launch control? Hondata's website says it has fuel cut.</TD></TR></TABLE>
If I knew how to post a screen shot I would, On the "Rev Limit" screen you can choose rev limit, what type of cut method "fuel" or "fuel & Ignition" with an overrun.
On the "Launch Control" ie. 2 step you set the launch activation and lauch limiter RPM and at that point you have an add fuel section and a retard timing section. One thing to note is the Hondata bounces much slower than the AEM so it takes a little longer to do the job, but it works.
Old Oct 23, 2006 | 06:18 AM
TurboCoop's Avatar
Default Re: (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">If I knew how to post a screen shot I would, On the "Rev Limit" screen you can choose rev limit, what type of cut method "fuel" or "fuel & Ignition" with an overrun.</TD></TR></TABLE>
open it up and hit "print screen", up above the delete key... then open it up in paint or something and then upload it to your server and you have the screen shot.
One more thing- I have hondata S100, which has no type of 2-step, but I have a MSD SCI ignition, can I wire up a MSD 2-step unit to this ignition, cause I think I read somewhere that I cant??? I would really like to have it cause I have slicks now and I still need some better 60' times...
Old Oct 23, 2006 | 08:03 AM
96 GSR-T's Avatar
Default Re: (TurboCoop)
There is no print screen, only setup and print.
Old Oct 23, 2006 | 08:07 AM
TurboCoop's Avatar
oh well thats the only way I know how to do it. I just sent an email to MSD to ask why you cant hook one up to a plain SCI box cause I wanna know what the difference is between it and the "L" version
Old Oct 23, 2006 | 08:16 AM
96 GSR-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCoop &raquo;</TD></TR><TR><TD CLASS="quote">oh well thats the only way I know how to do it. I just sent an email to MSD to ask why you cant hook one up to a plain SCI box cause I wanna know what the difference is between it and the "L" version</TD></TR></TABLE>
From what I understand, there is no difference between the SCI and 6A box, just size. The L is obviously an added limiter, I do not know if an SCI has that but I assume it does not.
Old Oct 23, 2006 | 10:40 AM
TurboCoop's Avatar
yeah they make SCI and SCI-L and 6A and 6AL, I wish I would have known back when I bought it like 3 years ago, ****
Old Oct 23, 2006 | 10:48 AM
TurboCoop's Avatar
I just got an email back from MSD:
Sir,
The main difference between the 6AL and SCI-L is the color and the
stickers. Other than that the two units are identical in output and
performance. You can have your SCI unit converted to accept an external
rev-limiter. The cost for this conversion is approximately $35.
The
external rev-limiter would be PN 8738, and the two-step would be PN
8979. If you want to send the unit in to have it converted, you will
need to call our customer service number for an RMA number and details;
such as, testing/repair charges, return address and the general process
or check us out online. If this equipment is less than a year old it may
be under warranty as well if you still have your receipt. We can be
reached @ 915-855-7123 Monday-Friday 7:00am-6:00pm Mountain time. Keep
in mind that we are closed on Saturday's and Sunday's. It is imperative
that you call for an RMA number before you send the unit or it will
dramatically slow down the repair process. You can also get an RMA
number from our website.
http://www.msdignition.com/rma
Thank you,
MSD Tech
I wonder what the "conversion" exactly is. I bet they just solder in a new wire or somthing stupid like that. I wish I didnt suck so much *** at wiring schematics or I would try to figure it out. I might have to start a new thread to try to get some help.
Old Oct 23, 2006 | 10:52 AM
4DRDB8GSR's Avatar
Here IS Your Print Screen
Old Oct 23, 2006 | 11:04 AM
4DRDB8GSR's Avatar
Default Re: (4DRDB8GSR)
Old Oct 23, 2006 | 11:37 AM
96 GSR-T's Avatar
how did u do that?
Old Oct 23, 2006 | 11:52 AM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">how did u do that?</TD></TR></TABLE>
- He hit the "Prt Scr" or "Prnt Scrn" or similar button.
- Opened paint. Hit "Ctrl" and "V" at the same time to paste.
- Saved as a JPEG.
- Upload to his cardomain.com site.
- Honda-Tech image link.
Old Oct 23, 2006 | 12:18 PM
4DRDB8GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AF-P Dunc &raquo;</TD></TR><TR><TD CLASS="quote">
- Saved as a JPEG.
Yup
Old Oct 23, 2006 | 01:40 PM
96 GSR-T's Avatar
Reason saying is because I tried it and it dont work for me, hit print, opened paint, hit cnt-v and nothing happened
