Homemade MAP limiter/ VAFC hack
Old Jun 20, 2002 | 09:34 AM
filetofit
Guest
Posts: n/a
Default Homemade MAP limiter/ VAFC hack
I'm in the process of building a MAP limiter circuit that limits the MAP signal to 2.88 volts. In other words it would eliminate the need for check valves, missing link etc. The same circuit would also be able to scale down the MAP signal so that you could use 450cc injectors with the stock ECU map, ie do the same thing as the VAFC hack without the VAFC. The circuit is based on op amps and is driven by the 5V reference the ECU provides for the MAP sensor. It is about the size of a large stamp. Would there be any interest in buying them for $20 preassembled? I'd be willing to post the circuit diagram once I get it tested and it's not real complicated but for those who aren't electrically inclined this would be a splice and go affair.
Old Jun 20, 2002 | 09:57 AM
EE_Chris's Avatar
Default Re: Homemade MAP limiter/ VAFC hack (filetofit)
Aside from the MAP limiting, it sounds like the HKS AFR deally. All it has is a single **** with adjustments of -3, -2....+2, +3 on it. I'm relatively sure it was a potentiometer changing the loopback gain of a common op-amp circuit. Is this what you had in mind....or something more fancy.
I'd be intrested in seeing the schematic when you get a chance to post it.
Old Jun 20, 2002 | 10:13 AM
ion_four's Avatar
looks like someone read:
https://honda-tech.com/zerothread?id=190336
I'm also going to use something similar. I think it'll use those one things...resistors...
Old Jun 20, 2002 | 10:18 AM
ion_four's Avatar
Default Re: Homemade MAP limiter/ VAFC hack (ion_four)
but, seriously...I think you might actually be able to avoid anything complicated by the use of two resistors and even a 2.8v zener diode, for good measure.
http://www.autospeed.com/A_0008/page1.html
I've posted this link a number of times, but no one seems to embrace it, heh.
Old Jun 20, 2002 | 10:38 AM
technine's Avatar
I'd be interested if it worked properly with 450cc injectors.
Old Jun 20, 2002 | 10:47 AM
CovertFI's Avatar
Default Re: Homemade MAP limiter/ VAFC hack (technine)
i would want it just for a map limiter but nothing else
Old Jun 20, 2002 | 10:53 AM
xci_ed6's Avatar
I have heard that Zener diodes "creep" up on the voltage, they have a little resistance before actually getting there.
I would be very interested in (esspecially in the diagrams of) the circuit.
-Dustin
Blk00EJ8
Aug 11, 2004 06:52 PM
forced-d16
Sep 22, 2002 11:46 PM
PrecisionPerformanceParts
Mar 12, 2002 02:53 AM
VTECHGSR
Dec 13, 2001 04:30 PM
LuderSH
Dec 10, 2001 12:17 PM
