Homemade adjustable wastegate?
Old Feb 24, 2003 | 02:41 AM
DSC's Avatar
DSC
Default Homemade adjustable wastegate?
Would this work? A friend of mine with a GM said I could do this for a internally wastegated turbo.
Old Feb 24, 2003 | 04:26 AM
Smashback's Avatar
Default Re: Homemade adjustable wastegate? (T3)
You must be a genius...
Thats what I call home made....I cant tell you if it will work..Doesnt even look like it will...
Anyway, yeah it will work but you can make a boost controller easier than you can do this.
Old Feb 24, 2003 | 04:31 AM
Tinker219's Avatar
Default Re: Homemade adjustable wastegate? (Hatchblack)
well every internal gated turbo that ive used comes from the factory like that...Kudos on the illustration/directions.
Old Feb 24, 2003 | 06:22 AM
civictypenos's Avatar
Default Re: Homemade adjustable wastegate? (DSC)
should work fine,i actaully had to do something similar to mine,im using a actuator from a talon,10 psi and was not adjustable,plus it didnt meet up with my t3 housing for mounting.i used the adjustable side of a volvo actuator,then cut off part of the talon one,threaded part of it and screwed on the volvo end,works like a champ.
Old Feb 24, 2003 | 10:07 AM
*Boostwerks*'s Avatar
You can't lower boost past the wastegates spring, with a booost controller...
That is why some people would be interested in this.
Old Feb 24, 2003 | 10:32 AM
sporkcrx's Avatar
Default Re: Homemade adjustable wastegate? (Bryson)
I did that on my old t25 to lower it to 5psi...it worked..but the lag SUCKED. I didn't build boost till about 4 or 5k.
Old Feb 24, 2003 | 10:37 AM
sporkcrx's Avatar
Default Re: Homemade adjustable wastegate? (sporkcrx)
Here's a pic of how I did it.
http://www.norcalcrx.org/spoon2/pics/adjwg.jpg
Old Feb 24, 2003 | 10:53 AM
Smashback's Avatar
Yeah I'm pretty sure you can lower it with an internal wastegate ... just like the Matrix "there is no spoon" but in this case, there is no spring
Unless I'm wrong, which is possible, my standard disclaimer.
Old Feb 24, 2003 | 12:05 PM
fsp31's Avatar
>>Yeah I'm pretty sure you can lower it with an internal wastegate...<<
The only ways I know of to lower boost below a certain point on internal waste gates is to lengthen the actuator arm (like the example in this thread), or do it "ghetto style" and steal the spring off grammas screen door, hook one end to the fan shroud and the other to your waste gate. Then you've got a nice "helper srping" setup.
Another option that works particularly well with large and/or restrictive intercoolers is to route the actuator vacuum hose as close as possible to the compressor (pre-intercooler). Then as RPM's increase (and air flow) you'll get this nice steady drop in boost pressure at the manifold. "chuckle"
tony413
Aug 3, 2008 09:12 AM
N20civicB18
Dec 27, 2006 09:22 AM
Dual_Phart_cans
May 19, 2005 02:07 PM
1boostedcivic
Sep 23, 2004 05:06 PM
green91
Jul 22, 2004 12:30 PM
