Home made setup
Old Mar 25, 2005 | 02:00 PM
ThaCivicAssassin's Avatar
Default Home made setup
I wanna make 160 hp on a eg LX with the D15 non v-tec............Can I add 60 hp with a home made kit without 2 many problems? also just wondering an estimate of how much psi id have 2 run on those numbers. Don't need 2 race just want it faster then the average 4-door on the road
Old Mar 25, 2005 | 02:07 PM
nonvtecD's Avatar
Yes, search or be flamed
Old Mar 25, 2005 | 02:25 PM
Default Re: (nonvtecD)
Wow ive just been inspired a performance d15 w/o vtec...............Ive done tons of research ...........And I want 2 build a small kit.....................I just don't know where to begin as far as the kit itself goes. I've researched the parts and im looking at a T3 set up.......Any advice? Im just kinda worried about install and tuning because I don't know who can do any of it. As far as prices go I've heard from 400 2 4000 so im looking at about 6-700 with home made setup. Any advice you could give me would be great........I looked at doing the mini-me but for the price I figured turbo is better plus more HP
Old Mar 25, 2005 | 02:40 PM
Default Re: (ThaCivicAssassin)
I guess I need a "Turbo Mentor" if U wil, and that what Honda-tech is to mel
Old Mar 25, 2005 | 03:06 PM
nonvtecD's Avatar
Yes turbo is better than mini me, http://www.ecimulti.org/uberdata for engine management. Get an ecu chip with a basemap by Xenocron. Get a junkyard T3, DSM injectors and Sidemount intercooler. Cheap log manifold etc... there's your junkyard kit.
Old Mar 25, 2005 | 03:40 PM
ace42004's Avatar
yep im almost done with mine...just need oil return line..and my ecu chipped with uberdata...all in all im happy...i spend about 600 on everything...
Old Mar 25, 2005 | 04:09 PM
Default Re: (ace42004)
damn man thanks so much U have no idea how much appreciate it.......t3's aren't that expensive right? so why not get a new one?.........Sounds good sounds good thanks again
Old Mar 25, 2005 | 04:22 PM
DragSource's Avatar
You D series guys have it made in the "cheap turbo" area.
Easily done for under a grand on a d-series.
Old Mar 25, 2005 | 06:52 PM
HiProfile's Avatar
Default Re: (DragSource)
You can get a used turbo that will last a long time if you look hard enough. I'd suggest a t25 from an s13 (usually at least one one ebay all the time), get a HF-to-t25 flange adapter from someone like WeiRacing (homemadeturbo.com forums), and the main items are done with. $150 for a great t25 (JDM s13's are usually junked or have the turbo upgraded before 50k miles), no need for a wastegate since it's inside the t25, $45 for hf/t25 adapter, $50 for dsm injectors, $40 for a 1g dsm BOV, $150 for madrel bent charge piping and downpipe tubing (if you have a friend that can weld), $75 for SS oil lines, $75 for dsm sidemount IC after you pay a welder ot mod it, $80 for cheap couplers, and $20 to chip your stock ecu (assuming it's currently OBD1) to use uberdata.
All told +60hp should be really easy to get, and the t25 will spool really quick. The other common option is to get a 14b (td05h) turbo from a 1g DSM, which also has an intergrated wastegate. All told, that still really cheap. More than a mini-me, but less than an installed ZC. Also more power than a ZC, let alone a stock b-series. By far the best way to go if you're shooting for 150whp.
Old Mar 26, 2005 | 06:32 AM
ace42004's Avatar
Default Re: (HiProfile)
yep what he say...i got my parts for cheaper then some price he listed too...it really easily done...but i been reading up on it since last december when i got my first honda...so just dont jump right into it...gotta do some research and look for the best deal.
Old Mar 26, 2005 | 07:20 AM
nonvtecD's Avatar
DSM sidemounts don't need to be modified and they cost $40
43!
Aug 22, 2015 10:15 AM
CRXherbie91
Jun 10, 2008 12:55 PM
vtec-2000
Dec 26, 2007 03:44 PM
J98BlueGSR
Dec 12, 2003 05:07 PM
mini-cRx
Dec 5, 2001 07:30 AM
