Hlp me solve my return line problem
Old Mar 15, 2011 | 12:49 PM
shocker911's Avatar
Default Hlp me solve my return line problem
ok so i have a problem how the hell can i do this return line with out touching the manifold??
here is a pic of what i have to work with
Old Mar 15, 2011 | 12:50 PM
shocker911's Avatar
Default Re: Hlp me solve my return line problem
if i need to buy a new oil pan no problem at all just want to do this damn return line and get it over with
Old Mar 15, 2011 | 02:02 PM
boostedBLUfg2's Avatar
put a 45* fitting off of the turbo. otherwise i'm not sure how else you could get it to angle away from it enough
Old Mar 15, 2011 | 02:03 PM
ignore that last post, i didn't see your return bung right there... think youre gonna need to cap off that return bung and weld a new one on the side, and probably still need that 45* fitting off the turbo as well
Old Mar 15, 2011 | 02:07 PM
wantboost's Avatar
Who is Mr Robot?
you need an angled fitting off of the turbo.... and if you heat wrap the return its ok if it touches a little bit
Old Mar 15, 2011 | 02:43 PM
shocker911's Avatar
so run a 45 degree off the turbo then heat wrap the line and i planned on hear wrapping the mani.
pjr710
Jan 14, 2010 03:28 PM
pokmijn
Mar 3, 2009 02:13 PM
BigZeke5
Oct 16, 2008 06:20 AM
TypeSLO
Mar 5, 2007 01:48 PM
sohc_vtec 2NR
May 6, 2004 10:32 AM
