HKS SSQ vs BLITZ
Old Jan 3, 2007 | 09:41 AM
jaywoodz's Avatar
Default HKS SSQ vs BLITZ
which is louder? pretty easy question. I've had the blitz for about a year running 15 psi daily, and it's decently loud, but sounds a bit muffled. I just ordered the HKS SSQ BOV, and I hope it was a good investment. I'm trying to determine which is going to be louder, thanks guys.
Old Jan 3, 2007 | 09:47 AM
Schister66's Avatar
Man U FTW
so you bought a new BOV in hopes that its louder??
Old Jan 3, 2007 | 10:01 AM
championshipwhite93si's Avatar
Default Re: (Schister66)
if you are looking for rice, try the rfl.. if you are looking for something that works look at tial...great sound
Old Jan 3, 2007 | 10:07 AM
jaywoodz's Avatar
Default Re: (championshipwhite93si)
ha, no. My current blitz bov sputters a lot, and I clean it over and over, and no matter how I adjust it, it sputters quite often. It was used when I got it, and I've used it for over a year, so I'm assuming that it's just going bad, or possibly because it's just a shitty bov. I got the HKS because of all the great reviews on it. I was simply curious if it was louder? I could barely hear my blitz.
Old Jan 3, 2007 | 10:33 AM
Ohgodzirra's Avatar
Default Re: (jaywoodz)
HKS is rather loud when its not recircd. So if you are going for a good clean sound, you have a winner. It's also alot better for running lower boost because of the design, so you shouldnt have any of the sputtering or compressor surge you had earlier. The Tial is amazing for higher boost, or when you are willing to commit to a certain boost level i.e. 25-28 and not 10-12 because of the spring ratings. The HKS gets away from that because of its design, but above 22 psi the tend to get a bit flakey. I've seen them hold higher than that just fine, and I've seen them start to freak out around 22psi. Also, adjusting the insert in the SSQV will change the sound remarkably.
Old Jan 3, 2007 | 11:14 AM
jaywoodz's Avatar
Default Re: (Ohgodzirra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ohgodzirra &raquo;</TD></TR><TR><TD CLASS="quote">HKS is rather loud when its not recircd. </TD></TR></TABLE>
what exactly do you mean by that?
Old Jan 3, 2007 | 11:28 AM
Mykizism's Avatar
means my ebay cold air intake is louder than a recirculated bov.
Old Jan 3, 2007 | 11:33 AM
jaywoodz's Avatar
Default Re: (Mykizism)
forgive me for asking this, but what do you mean by recirculated? I don't know a whole lot about BOV's.
Old Jan 3, 2007 | 11:38 AM
Mykizism's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaywoodz &raquo;</TD></TR><TR><TD CLASS="quote">forgive me for asking this, but what do you mean by recirculated? I don't know a whole lot about BOV's.</TD></TR></TABLE>
recirculated means the air that comes out of the blow off valve.. goes back into the intake pipe (inlet side of the turbo).. its a closed system, usually for MAF (mass air flow) systems.. like toyota supras, nissans.. so on..
uncirculated means the air that comes out of the blow off valve.. is vented to the open atmosphere.. which most honda guys run because we are on a speed density (map system)
Old Jan 3, 2007 | 11:43 AM
jaywoodz's Avatar
I understand a little better now. So my HKS is a an uncirculated bov? correct?
Old Jan 3, 2007 | 11:45 AM
ExVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ohgodzirra &raquo;</TD></TR><TR><TD CLASS="quote">HKS is rather loud when its not recircd. So if you are going for a good clean sound, you have a winner. It's also alot better for running lower boost because of the design, so you shouldnt have any of the sputtering or compressor surge you had earlier. The Tial is amazing for higher boost, or when you are willing to commit to a certain boost level i.e. 25-28 and not 10-12 because of the spring ratings. The HKS gets away from that because of its design, but above 22 psi the tend to get a bit flakey. I've seen them hold higher than that just fine, and I've seen them start to freak out around 22psi. Also, adjusting the insert in the SSQV will change the sound remarkably.</TD></TR></TABLE>
So....are you saying that hks units start to leak around 22+psi?
Old Jan 3, 2007 | 12:09 PM
Mykizism's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaywoodz &raquo;</TD></TR><TR><TD CLASS="quote">I understand a little better now. So my HKS is a an uncirculated bov? correct? </TD></TR></TABLE>
the unit alone is uncirculated yes.. it can be made to be recirculated as well..
Old Jan 3, 2007 | 12:19 PM
jaywoodz's Avatar
Alright, my next question is probably a dumb one, but one of the reasons I would like to be able to hear my BOV a little better is to monitor the sputtering on it. I am hoping to get rid of that one I install this HKS SSQ. I'm sure you've heard blitz and this HKS, much of a difference? performance and sound?
Old Jan 3, 2007 | 01:52 PM
Mykizism's Avatar
i like my hks better than my blitz.. they both work really good. its just a matter of preference..
Old Jan 3, 2007 | 01:57 PM
jaywoodz's Avatar
does your blitz ever sputter? how much boost are you running? does the hks sound better/louder? what is your detailed opinion? thanks!
Old Jan 3, 2007 | 02:27 PM
vtec.dc2's Avatar
Default Re: HKS SSQ vs BLITZ (jaywoodz)
i run knock off hks, i used to have the real one. i think hks style is the best cause it works for all boost levels. i do'nt know about high hp and i guess thats why the make the race version.
Old Jan 3, 2007 | 02:40 PM
Sprockets's Avatar
I love my Blitz. I have had it for over a year and never cleaned or adjusted it. I have a direct vacuum line going to my intake manifold. It's perfect. More than likely vacuum is your problem. Try loosening it. If you want to squeak around the neighborhood and attract attention, get the HKS. By the way, even Tials flutter, but people call it a rattlesnake sound because it a blingin' Tial 'yo.
Old Jan 3, 2007 | 02:46 PM
jaywoodz's Avatar
Default Re: HKS SSQ vs BLITZ (Sprockets)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sprockets &raquo;</TD></TR><TR><TD CLASS="quote">If you want to squeak around the neighborhood and attract attention, get the HKS. </TD></TR></TABLE>
I already ordered the hks, this is the first I've ever heard that the HKS is actually louder then the blitz.. weird. So it is definately louder than the blitz? Thanks for the quick replies!
Old Jan 10, 2007 | 09:04 AM
ExVtec's Avatar
Here is a video of my car w/the hks..
SiAdam
Total Running Time - 4:55
Total Video - 4:33
Total Size - 18.7mb
Windows Media player compatible.
Also mirrored on
Youtube.com
Streetfire.com
Old Jan 10, 2007 | 01:31 PM
raceACCORDingly's Avatar
I thought the SSQV was the least responsive BOV amongst all the big name ones like greddy, tial, turbosmart, blitz, etc... well atleast thats what Ive read numerous of times on here.
Old Jan 10, 2007 | 11:03 PM
Herzeleid's Avatar
I am trying to complete a custom turbo kit... why don´t you sell me your blitz bov? hehe, JK.
I´ve heard the HKS SSQV and it isn´t Rice at all. I heard one "RAPTOR" and the sound is cool. I think that Greddy makes raptor.
Old Jan 11, 2007 | 07:33 AM
Mr.60trim's Avatar
From: What Business is it of yours where Im from Friendo
Default Re: HKS SSQ vs BLITZ (ExVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExVtec &raquo;</TD></TR><TR><TD CLASS="quote">Here is a video of my car w/the hks..
SiAdam </TD></TR></TABLE>
God I love that sound!!! Nice vid as well...
Old Jan 28, 2007 | 09:30 AM
ExVtec's Avatar
Default Re: HKS SSQ vs BLITZ (Team_Carnage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team_Carnage &raquo;</TD></TR><TR><TD CLASS="quote">
God I love that sound!!! Nice vid as well... </TD></TR></TABLE>
Thanks.
k4rts
Jul 20, 2006 04:50 PM
alfee
Jan 13, 2004 08:20 AM
integranator
Jul 22, 2003 11:00 PM
SPORE
Jun 2, 2003 10:55 AM
