Highest HP on stock LS head?
Old Oct 4, 2013 | 01:26 AM
TravisBiggie's Avatar
Default Highest HP on stock LS head?
Someone I know locally said hes seen a stock ls head hit 460whp with a large turbo. Is this possible? out of scanning through tons of pages on the ls-t thread, i haven't seen more than 400whp, and I don't know if these are on dyno jets or mustang dynos.
I am planning on hitting over 400whp soon with methanol injection, 25+ psi. I may be picking up a t3 t67 turbo, but not 100% sure yet.
Old Oct 4, 2013 | 01:51 AM
Turbo-LS's Avatar
Default Re: Highest HP on stock LS head?
define "STOCK" because some consider stock just the porting but everything else upgraded. IMO stock is stock and you wont see much over 400 with a completely stock head and your going to need a whole bunch of RPM with a laggy *** t3/t67 to see power so it wont really be "STOCK" if you do cam and valve spring upgrades
Old Oct 4, 2013 | 02:21 AM
touche.
stock, untouched head. stock ports, cams, retainers, springs, cams gears, intake manifold, throttle body. I guess i'll ditch the t3 t67 idea. Unless you can recommend another turbo for 650-700 that is t3 and capable for ~700hp? I think the closest is a 6262? But I haven't seen those cheaper than a grand.
Old Oct 4, 2013 | 03:20 AM
Turbo-LS's Avatar
You can't obtain those numbers with a stock head. You need springs retainers and a set of cams that will carry the torque curve higher regardless of which turbocharger chosen for that power level. The LS head just doesn't flow like a vtec head. It will take more boost to hit same hp levels and generally a given turbo will not produce the same peak number even when maxed out. IE a 700hp turbo on an ls will probably make around 600-625 vs a vtec head will hit the 700
Old Oct 4, 2013 | 04:20 AM
LightningTeg's Avatar
Community Builder
This is like the 5th thread you've made about "How much power if xxx on LS head".
Just suck it up and buy some cams already.
Old Oct 4, 2013 | 04:23 AM
Turbo-LS's Avatar
Or a vtec head. Lol
Old Oct 4, 2013 | 04:26 AM
Community Builder
Originally Posted by Turbo-LS
Or a vtec head. Lol
Yeah it would make life easier too. I just had to be different
Old Oct 4, 2013 | 05:37 AM
Turbo-LS's Avatar
I tried different years ago and I waste a ton of money on a LS head. Shoulda just went vtec then.
Old Oct 4, 2013 | 05:44 AM
Community Builder
I havent put any money into my head since I bought it
TravisBiggie
Aug 23, 2013 04:55 AM
842177
Dec 16, 2008 07:15 AM
chrisgottigsr
Mar 12, 2006 07:56 PM
buttsneeze
Feb 2, 2006 09:06 PM
egvtec
Nov 26, 2004 04:00 PM
