high oil pressure! HELP!
Old Aug 6, 2007 | 10:49 PM
crxkid24's Avatar
Default high oil pressure! HELP!
i know i know another one of these threads. i read most of them. but still confused. when i start my car the gauge flys by a 100 psi all the way back to the needle. it a mechnical gauge and yes i bought a brand new one and it did the same thing. i tried changing the oil and filter...same thing. it has a endyn racing oil pump with only a couple thousand miles on it and its ls vtec turbo. i dont see how it could be the relief valve the pump is almost new. when the car warms up it goes to about 60 psi at idle but if i rev it to about 3k it will jump well over a 100 psi. if the oil pressure really was that high wouldnt i be blowing oil out everywhere??? i see no oil at all. the motor sounds like it runs just fine. the car drove fine since the turbo kit was put on about 2 weeks ago...perfect oil pressure. it doesnt make any sense to me. someone please help me i have been trying to figure this out for the last couple days cant seem to figure it out.
Modified by crxkid24 at 8:00 AM 8/7/2007
Old Aug 7, 2007 | 06:12 AM
JDMCRX's Avatar
Default Re: high oil pressure! HELP! (crxkid24)
Its a mechanical gauge. Give it a few days. if not there is a big air bubble in there. U can pull the line off the gauge and put it in a beer bottle and just crank the car over real quick and re attach it.
Old Aug 7, 2007 | 07:49 AM
crxkid24's Avatar
yeah but the gauge has been on the car for 8 months now never had a problem with it until a couple days ago.
Old Aug 7, 2007 | 08:27 AM
crxkid24's Avatar
no one else???
Old Aug 7, 2007 | 08:35 AM
awdgsx96's Avatar
Default Re: (crxkid24)
My friend's Eclipse shot up to about 90psi at cold idle. After that a while it dropped down to about 60.
What does it do while driving?
Old Aug 7, 2007 | 06:34 PM
crxkid24's Avatar
drives fine until i go to get on it a lil it shoots up past a 100 psi.
Old Aug 8, 2007 | 04:20 AM
awdgsx96's Avatar
Isn't ~90-100 psi normal right on WOT?
I don't know about >100 psi though
Old Aug 8, 2007 | 04:49 AM
motormike40's Avatar
If you are running a restrictor on you oil feed line it could be that. I
drlagares
Aug 8, 2016 06:43 AM
wearyfurball
Aug 25, 2008 04:39 PM
Monkey Fing a Coconut
Oct 31, 2004 05:29 AM
smokey2.0
Apr 20, 2004 01:33 PM
HX_Guy
Dec 5, 2001 02:49 PM
