Lower oil pressure after rebuild
Old Dec 5, 2001 | 02:01 PM
HX_Guy's Avatar
Default Lower oil pressure after rebuild
What does this mean? Is it a bad thing?
I used to get right around 70-72 PSI at 3000 RPMS before the rebuild, and now its right around 65 PSI. Idle is still the same as it was before at around 20 PSI.
I was using Mobile 1 before and now Im using regular oil, not sure if that has an effect on things.
Should I be concerned?
Old Dec 5, 2001 | 02:29 PM
sgT's Avatar
sgT
Default Re: Lower oil pressure after rebuild (HX_Guy)
new oil pump?
change the oil and see what happens. but as long as its over 50 you should
be ok.
Old Dec 5, 2001 | 02:32 PM
HX_Guy's Avatar
Default Re: Lower oil pressure after rebuild (sgT)
Yes I got a new oil pump as well..maybe that is why its lower now.
Ill be changing this oil at 1000 mile mark and we'll see then.
Is synthetic thinner/thicker then regular oil? Would it cause a change in pressure?
Old Dec 5, 2001 | 02:49 PM
sgT's Avatar
sgT
quite possibly.
I put an oil pressure gauge on a b18a recently, average pressure was 90!
nonpoint986
Apr 13, 2011 08:38 PM
fr3dy_1
17
May 23, 2008 11:33 PM
hatchinprogress
Jan 7, 2006 07:48 AM
vtec.dc2
Feb 1, 2004 10:49 AM
gaskleppie
Sep 27, 2003 06:45 AM
