High Boost troubles
Old Apr 24, 2003 | 10:09 AM
boosted6thgen's Avatar
Default High Boost troubles
I have been having problems with my car(97 Civic w/greddy turbo) at 8-10psi for almost a month and still cant find the problem. At 6psi my car pulls to the redline no problems. But once I go to 8-10psi, the rpms just jump to the redline once I hit around 5-6k(it varies from time to time) and it sounds like a bog. I have an ACT extreme pressure plate rated at 275lbs/ft. so it shouldnt be slipping. I have an upgraded fuel and ignition system that are plenty adequate. Is it possible that when my flywheel got resurfaced that it got stepped down too far? I am out of ideas on what the problem is, so ANY suggestions or ideas are greatly appreciated.
Old Apr 24, 2003 | 10:40 AM
UberTeg's Avatar
Default Re: High Boost troubles (boosted6thgen)
wheelspin ownz jo0
Old Apr 24, 2003 | 10:52 AM
Default Re: High Boost troubles (UberTeg)
In 3rd and 4th gear? I dont think so.
Old Apr 24, 2003 | 11:05 AM
UberTeg's Avatar
well you should have said u were in 3rd / 4th
SOMETHING is slipping if your rpm's soar and you'ren ot going any faster. And its impossible to bog and make MORE power to cause something to slip.
Old Apr 24, 2003 | 11:24 AM
genop's Avatar
you said you had the ACT pressure plate, are you using the disc as well?
Old Apr 24, 2003 | 11:45 AM
Gravy's Avatar
Default Re: High Boost troubles (genop)
slipping clutch.
SOHCex20
Jul 29, 2005 07:11 AM
budget
Apr 4, 2005 08:00 AM
afrothunda713
Oct 9, 2004 09:27 AM
Cee_mon
Apr 8, 2004 03:44 PM
Ricey McRicerton
Sep 23, 2003 10:17 AM
