Does this make sense? Car sputtering
Old Sep 19, 2012 | 10:20 PM
rfelix89's Avatar
Default Does this make sense? Car sputtering
im having issues with my car sputtutring bad on high boost. my 2nd gear is set up to 14psi car runs fins. then when i throw it into 3rd my boost is set up at 24 psi thats when the car starts sputtering bad. same goes with my 4th. 1st and second are fine. the only thing i did to the car was change my FPR i had and got tuned using an AEM with a base fuel pressure of 45psi. i swapped my rail and also installed an aeromotive i had laying around...would the 1:1 lb of pressure per lb of boost affect/ throw off my high boost tuning. im running ngk 8s gapped at .15
Old Sep 19, 2012 | 10:34 PM
SonicRacing1's Avatar
Default Re: Does this make sense? Car sputtering
Sound like a retune session is in order
Old Sep 19, 2012 | 10:37 PM
rfelix89's Avatar
yup thats what its started to come down too.
Old Sep 19, 2012 | 11:02 PM
a1320honda's Avatar
Do you have a wideband in the car? I would think that either datalogging an accurate AFR or having a wideband in the car at that much boost would be a necessity. Sounds like an AFR problem, or could be time for a new coil/igniter/plugs or wires. But changing something like the rail and regulator from stock to aftermarket are going to require a retune.
Old Sep 20, 2012 | 12:50 PM
rfelix89's Avatar
well beign that im fairly new to the whole s300 system i havent really figuered out the whole datalogging thing.
Old Sep 20, 2012 | 12:53 PM
rfelix89's Avatar
would running c16 cause my o2 from my wideband to not read correctly? cuz after i started running the racefuel my widebamd just stays at like 14.2 reguardless of how im driving it
rfelix89
Sep 20, 2012 11:43 PM
umair
Oct 17, 2011 08:48 AM
b_ron007
May 19, 2004 06:29 AM
squeaky
May 14, 2002 07:07 PM
