Hey, is it cool to wrap the down pipe with heat wrap?
Old May 22, 2002 | 08:08 AM
b18tdelsol's Avatar
Default Hey, is it cool to wrap the down pipe with heat wrap?
I'm using the down pipe thats included in the revhard kit, but was wondering wraping the down pipe with heat wrap would cause any issues? I mean, since its near the oil return line, i thought it would be added safety from getting the oil return line too hot.. what do u guys think? it's the kind of heat wrap thats use to wrap headers.
Old May 22, 2002 | 08:41 AM
Kevin's Avatar
Default Re: Hey, is it cool to wrap the down pipe with heat wrap? (b18tdelsol)
I've wrapped headers (that get glowing red hot) on supercharged cars, had no problems in over 2 years of driving. People say that the wrap can break welds but ive never seen it happen. Just make sure you only overlap the wrap by about 3 cm so its barely covering itself, try not to wrap it too thick. I wrapped the downpipe on our Greddy kit to try and keep heat from the oil pan and lines.
[Modified by 5speedv6, 5:41 PM 5/22/2002]
Old May 22, 2002 | 11:18 AM
rjardy's Avatar
Default Re: Hey, is it cool to wrap the down pipe with heat wrap? (5speedv6)
it will work......
Rob
Old May 22, 2002 | 12:11 PM
GruvyTune's Avatar
New User
do it the other way around.
slip the oil line in some Fyrejacket insulation at the spot where it is near the downpipe. Works great!
Old May 22, 2002 | 12:15 PM
VTC_CiViC's Avatar
Default Re: Hey, is it cool to wrap the down pipe with heat wrap? (GruvyTune)
I wrapped my DP a while back too.. works just fine.
Old May 22, 2002 | 01:08 PM
b18tdelsol's Avatar
Default Re: Hey, is it cool to wrap the down pipe with heat wrap? (VTC_CiViC)
yeah, i think im gonna wrap both, the return line and the dp..
Old May 22, 2002 | 01:25 PM
Flamenco-T's Avatar
Default Re: Hey, is it cool to wrap the down pipe with heat wrap? (Sayang)
you want the DP and the manifold to be as hot as possible...
wrap the oil return, leave the DP and Manifold as hot as possible, it needs to be hot and let ir cool slowly..
Old May 22, 2002 | 03:16 PM
ThePunk's Avatar
Default Re: Hey, is it cool to wrap the down pipe with heat wrap? (Flamenco-t)
Wouldn't wrapping the DP keep it as "hot as possible" and let it cool "slowly"?
Old May 22, 2002 | 04:36 PM
.nate's Avatar
Default Re: Hey, is it cool to wrap the down pipe with heat wrap? (ThePunk)
You would think that the heat wrap would retain heat and not let it escape...
Old May 22, 2002 | 09:16 PM
speshuled619's Avatar
why wood you want the manifold and the dp to be as hot as possible? are you saying not to wrap it?
Old May 22, 2002 | 09:46 PM
b18tdelsol's Avatar
Default Re: Hey, is it cool to wrap the down pipe with heat wrap? (speshuled619)
To wrap or not to wrap, that is the question.
Old May 22, 2002 | 09:47 PM
echo999's Avatar
New User
Hey.. that firejacket stuff is expensive.. Any cheaper alternatives?
I wrapped mine in adhesive aluminum tape, and it's been fine for 7 months now.
Old May 28, 2002 | 12:20 PM
csufweed's Avatar
Default Re: Hey, is it cool to wrap the down pipe with heat wrap? (echo999)
exhaust gasses move faster when hot, this is why keeping the dp hot is good... a heat wrap would help retain more heat... in fact wrapping your whole exhaust will provide a small gain in power.
Old May 28, 2002 | 02:10 PM
inspyral's Avatar
Default Re: Hey, is it cool to wrap the down pipe with heat wrap? (csufweed)
Will wrapping the dp make it more likely to crack? My dp's structural integrity is already a bit sketchy as it is...
Old May 31, 2002 | 12:19 PM
tonydatyga's Avatar
Default Re: Hey, is it cool to wrap the down pipe with heat wrap? (inspyral)
If its not broken, don't fix it.
Old May 31, 2002 | 06:11 PM
inspyral's Avatar
Default Re: Hey, is it cool to wrap the down pipe with heat wrap? (tonydatyga)
I guess it stays ugly and unwrapped, then
Old May 31, 2002 | 08:40 PM
saso
Guest
Posts: n/a
Correct, hot air travels faster than slow dense cool air.
2kdrift
Jan 28, 2017 06:15 PM
Attoir
Mar 19, 2006 04:01 PM
_Endless_
Dec 8, 2003 09:48 PM
SI_DRIVR
Feb 4, 2003 08:11 AM
b18tdelsol
May 18, 2002 11:33 AM
