hesitation?
Old Nov 15, 2003 | 10:32 PM
GDM Z28's Avatar
Default hesitation?
when i nail it and say im in 2nd, once boost kicks in i hear the wastegate open but it feels like its laggy then it like kicks in again. could this be caused by stock plugs? BTW my set up is a T3 on a b18b with a 3.5 psi spring (yeah i know its a ***** amount but i havent installed my boost controller yet)
**EDIT** (forgot to post my fuel set up) im running 450cc DSM injectors on the SAFC hack. my settings are -35% for idle and -27% across the board. **/EDIT**
Old Nov 15, 2003 | 11:57 PM
rjardy's Avatar
Default Re: hesitation? (civicflnum1)
27% is allot of fuel, are you sure your not rich?
Rob
Old Nov 16, 2003 | 05:31 AM
GDM Z28's Avatar
Default Re: hesitation? (rjardy)
i know its alot but thats what we set it at to be safe...you think thats whats causing it?
Old Nov 16, 2003 | 05:59 AM
baddassduramax's Avatar
sounds rich to me...prolly part of the problem
Old Nov 16, 2003 | 08:37 AM
GDM Z28's Avatar
Default Re: hesitation? (civicb18)
i guess ill get new plugs and get the car dyno tuned then ill see what happens
Old Nov 16, 2003 | 10:24 AM
b16ahybrid's Avatar
It's because your runing too rich, and runing overly rich is not good, its not as damaging as runing lean but it is damaging....
get some colder plugs gap them properly and get your car on a dyno.
Old Nov 16, 2003 | 06:13 PM
GDM Z28's Avatar
Default Re: hesitation? (b16ahybrid)
ok thanx man...ill let u know what happens after that
Old Nov 16, 2003 | 06:18 PM
Mr. Softee's Avatar
run colder plugs for starters.
you could be rich or lean theres no telling without wideband usage.
Old Nov 17, 2003 | 02:39 AM
GDM Z28's Avatar
Default Re: hesitation? (94goldjungsr)
well im running -27% on 450's and everyone else is runing like -32 or higher so im pretty sure im rich
Old Nov 17, 2003 | 06:30 AM
im at -36% to -40% on dsm 450's and my plugs are blacker than dark of night
Old Nov 17, 2003 | 10:54 AM
GDM Z28's Avatar
yeah...i need to get this **** on a dyno soon. BTW what plugs are you using?
Old Nov 17, 2003 | 11:07 AM
im using ngk - bkr7e
Old Nov 17, 2003 | 11:09 AM
GDM Z28's Avatar
do u have aim/aol? i have some more ?'s
bowtieboy911
Engine Management and Tuning
Jun 4, 2011 04:32 AM
1baddturbosi
Oct 29, 2007 10:56 PM
cliff666
Aug 1, 2004 11:04 AM
sneakypete
May 29, 2003 02:35 PM
Nate B
Feb 10, 2003 08:26 PM
