12.3 AFR at full-throttle, is that the norm?????
Old Oct 29, 2007 | 06:47 PM
1baddturbosi's Avatar
Default 12.3 AFR at full-throttle, is that the norm?????
I found some mis-gapped spark plugs some shop put in my car, then put new ngk plugs gapped to .30 in & she runs 2x better, but doesnt have "that" pull it had before. I check my AFR at WOT & it was about 12.0-12.5, is that ok??
Dont want something stupid to happen!!!!
Old Oct 29, 2007 | 07:04 PM
iBrandon's Avatar
Default Re: 12.3 AFR at full-throttle, is that the norm????? (1baddturbosi)
how much boost? a little lean for my taste...i would run around 11.5-11.8
Old Oct 29, 2007 | 07:08 PM
redzcstandardhatch's Avatar
something different
Default Re: 12.3 AFR at full-throttle, is that the norm????? (iBrandon)
i agree. on a simple, lower power setup, it might be fine..
Old Oct 29, 2007 | 07:09 PM
9.5-10psi off wg spring. I just dont wanna get on it & have something go wrong.
It runs absolutely great, not jumpy or running rough anymore!!!
It made 276whp on those plugs, i lost a little power but i bet on a good set of plugs & a better tune, maybe more power???
Old Oct 29, 2007 | 07:12 PM
iBrandon's Avatar
what ems are u running? I would add more fuel on ur boost columns...unless ur running lean overall, then u may need a retune or an overall fuel trim adjustment
Old Oct 29, 2007 | 07:16 PM
AEM ems-1010
Old Oct 29, 2007 | 07:48 PM
blackeg's Avatar
gap them closer, maybe .026 or .028. it only takes a second and is free to do
Old Oct 29, 2007 | 07:54 PM
Default Re: 12.3 AFR at full-throttle, is that the norm????? (blackeg)
car is in my storage garage, ill try that 2morow, what is the benefit of that???
Old Oct 29, 2007 | 07:56 PM
blackeg's Avatar
it helps keep the spark "together" and from blowing around with the flow of the air.
avoiding something called spark knock. i dont think your flowing enough air to make it necessary, but its a nice try. 12:1 isnt that lean that your car will feel noticeably different
Old Oct 29, 2007 | 08:00 PM
yeah, the car ran ok before, but i pulled the plugs just for *****/giggles, #1cy=.32, #2=.32, #3=.28, & #4=.35
Old Oct 29, 2007 | 10:56 PM
FaceTuned's Avatar
whoever gapped number 3 was trying to compensate for something.
and 12.0 is perfect for 10lbs
Modified by FaceTuned at 8:15 AM 10/30/2007
bowtieboy911
Engine Management and Tuning
Jun 4, 2011 04:32 AM
Honda4life777
Jul 23, 2009 05:36 PM
u_tal
Nov 10, 2004 03:01 PM
r7
Aug 26, 2003 05:18 AM
Blue-Civic-Hybrid
Jul 11, 2003 11:07 AM
