Help! Weird wasegate issues
Old May 20, 2006 | 08:21 PM
Integra_drk's Avatar
Default Help! Weird wasegate issues
I keep burning through wastegate gaskets. its the gasket from the manifold to the wastegate. On the side of the wastegate closest to the motor, it keeps like melting half an inch of the gasket. The gasket will last about a week and then you can hear the exhaust leak. when i take the wastegate off, the gasket is like falling apart. I even used gasket maker/sealant and it lasts a day and it comes off on that same spot. I have no idea why and the exhaust leak is driving me crazy. TIA
Old May 21, 2006 | 06:35 PM
Default Re: Help! Weird wasegate issues (Integra_drk)
ttt
Old May 22, 2006 | 09:43 AM
anyone got anything?
Old May 22, 2006 | 09:58 AM
ekhatchgrl's Avatar
I would assume that the actual flages are not machined perfectly flat and that is causing a small amount of exhaust gas to pass through till it eventually burn a bigger hole.
Old May 22, 2006 | 10:14 AM
Default Re: (ekhatchgrl)
true, meaning i would have to get both surfaces machined huh.
Old May 22, 2006 | 10:22 AM
atec's Avatar
Default Re: (Integra_drk)
Try swirl the metal with a soft swirlpad, add a thin layer liquid copper grease(spray) and tighten the two ends together without the gasket.
Old May 22, 2006 | 10:33 AM
Default Re: (atec)
will do. thanks
Old May 22, 2006 | 11:10 AM
yee SERIOUS's Avatar
35-38mm wg? burnin the gasket? check it out!
http://www.atpturbo.com/Mercha...e=GSK
Old May 22, 2006 | 11:19 AM
The Destroyer's Avatar
Default Re: (undercoverdc2)
If you arent using lockwashers get some. My wastegate was coming loose and and luckily I caught it before any damage took place.
Old May 22, 2006 | 11:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 &raquo;</TD></TR><TR><TD CLASS="quote">35-38mm wg? burnin the gasket? check it out!
http://www.atpturbo.com/Mercha...e=GSK</TD></TR></TABLE>
how would this be different than any other gasket? i keep burning through them so id need like a metal gasket or something.
Old May 22, 2006 | 11:26 AM
ladysman's Avatar
which ones are you using now?
The ones in the link above are firering gaskets and are semi-metal reinforced. I use them and never had an issue on all my setups. I am still using the same gaskets actually.
Old May 22, 2006 | 11:48 AM
Default Re: (ladysman)
hmm well i have been using the ones directly from tial and ive gone through 3. ill try one of the above, thanks.
Old May 22, 2006 | 12:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">which ones are you using now?
The ones in the link above are firering gaskets and are semi-metal reinforced. I use them and never had an issue on all my setups. I am still using the same gaskets actually.</TD></TR></TABLE>
yeah tial gaskets suck. i blew 2 of them on my 38mm tial wg. one actually blew and rolled up into a ball. i found it when i took off my wg once i ordered my "firering wastegate gasket". no more problems this gasket was made for the deltagate i believe, but works great with the tial wg.
fire ring gasket FTW
Old May 22, 2006 | 12:24 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_drk &raquo;</TD></TR><TR><TD CLASS="quote">hmm well i have been using the ones directly from tial and ive gone through 3. ill try one of the above, thanks.</TD></TR></TABLE>
That's your problem order these and problem will be solved.
GWInquisitor14
Sep 25, 2005 11:30 AM
Vinhtran17
May 12, 2004 02:21 PM
XBoostedAccordX
Oct 18, 2003 09:31 PM
Bspec18
Jul 3, 2003 09:32 PM
Etylorcen
Feb 24, 2002 01:39 PM
