Help on wastegate options???
Im buidling a D15b turbo and i need help on choosing the wastegate springs...its a fully built head P&P new valves bisimoto 2.4 cam bisimoto springs and retainers, bottom end has FJ spec-r rods with vitaras fully balanced rotating assembly! Spoolinperformance quick4-AC manifold with a Garrett 57 trim T3/T4 .63 ar.....Any help would be appreciated! Car will be driven for race purpose on the weekends with C16 and Regular pump gas once and a while during the week! Thanks in advance for your help!!!
How much are you planning to boost? I have an 8psi spring and so far I have been able to boost 20psi with no problem. If you are planning to boost more than that go for the 1Bar spring.
im hoping to get about 28psi for the track HOPEFULLY! But imma turn it down for the street! If i turn the boost down for the street wont it throw the engines performance a little off due to a bigger WG spring? Just asking dont know to much about WG psi's thanks for your help if u have anymore info please LMK
