Help with wasteagte.....
Old Aug 13, 2002 | 06:16 PM
APEXI Si's Avatar
Default Help with wasteagte.....
i bought a t3 turbo from a saab 9000 and it has ajustable wastegate that is set at 11psi stock and i want to run 6psi so when i adjust the pole out it puts the flapper open all the way so what can i do to get the boost down. cause if its open all the way it wont spool right? please help
also longer shaft the lowerr boost right
Old Aug 13, 2002 | 07:38 PM
KevronsEG's Avatar
Default Re: Help with wasteagte..... (crx616)
bump
Old Aug 14, 2002 | 05:27 AM
KevronsEG's Avatar
Default Re: Help with wasteagte..... (CIV616)
bump
Old Aug 14, 2002 | 05:34 AM
DSF's Avatar
DSF
Yes. You are relieving spring pressure on the diaphragm, so it takes less boost pressure to move it.
avsrule414
Dec 10, 2005 09:07 AM
SwIntegraB16
Jul 7, 2005 05:15 PM
T25So
Aug 15, 2004 08:20 AM
integ2
Jun 15, 2004 06:44 PM
Ri5e
Sep 2, 2001 09:01 PM
