HELP PLEASE!! At the top of second gear i get a CEL code 3
Old Oct 6, 2002 | 08:51 PM
b16sir1's Avatar
Default =( HELP PLEASE!! At the top of second gear i get a CEL code 3 =(
I get this cel a 9lbs of boost can i correct this with my V-AFC
I'm not sure what to do with this V-AFC?
1. [Wide Thr]
2. [Narr. Thr]
3. [V/T Cont]
4. [V/T Unmt]
5. [TH-Point]
6. [Ne-P:Hvt]
7. [Ne-P:Lvt]
which on do i use to correct this problem?
Ok heres my set up!
V-Afc
no missing link or check valves
Tial 35mm Wastegate 9LBS Spring
T3/04e 60-1 Turbo
No Boost Controller
[Modified by b16sir1, 1:28 AM 10/7/2002]
Old Oct 6, 2002 | 09:27 PM
b16sir1's Avatar
Default Re: HELP PLEASE!! At the top of second gear i get a CEL code 3 (b16sir1)
anyone can you help??
Old Oct 6, 2002 | 09:36 PM
98civicEX's Avatar
CEL 3 Manifold Absolute Pressure Sensor
Open or short in MAP sensor circuit, bad MAPS
what are your settings for the VAFC? is it going in limp mode?
Old Oct 6, 2002 | 10:03 PM
b16sir1's Avatar
Default Re: HELP PLEASE!! At the top of second gear i get a CEL code 3 (98civicEX)
it goes to limp mode a 7500 in second gear?
Old Oct 6, 2002 | 10:07 PM
boostinb18's Avatar
are you running larger injectors?? and maybe your boost gauge is wrong and your going above 10 psi where you will throw a map cel because the vafc can only compinsate up until 10 psi.
Old Oct 6, 2002 | 10:15 PM
b16sir1's Avatar
Default Re: HELP PLEASE!! At the top of second gear i get a CEL code 3 (boostinb18)
I have a Tial Wastegate 9lbs spring
Old Oct 6, 2002 | 11:16 PM
Evil EG's Avatar
Check your Pressure wire on your V-AFC. I had the same problem and it ended up being my pressure wire was loose. Also if you dont have a missing link or check valves, that could cause it also.
Old Oct 6, 2002 | 11:31 PM
b16sir1's Avatar
Default Re: HELP PLEASE!! At the top of second gear i get a CEL code 3 (BVM)
I'll Check that
DarkBB4
Dec 12, 2004 11:56 AM
nigel
Jul 14, 2003 01:00 PM
.Beaver
28
Nov 19, 2002 04:31 PM
TurboBumblBee
Nov 14, 2002 01:09 PM
VTECHGSR
Dec 12, 2001 08:55 AM
