Difference between code 3 & 5
Old Jan 25, 2007 | 02:30 PM
93sidelsolvtec's Avatar
Default Difference between code 3 & 5
I have a 2001 h22 in my 90 accord.
The guy that put it in there tried to run it off the map on the throttle body. This resulted in a code 3. Map sensor code
I took it off and plugged it into the map that is stock on the accord. One the firewall behind the throttle body. The code disappeared but now the car runs rough. Now vtec works and the car can rev past 6k. The car doesnt want to idle and tries to die.
after I let it idle for 2-3 mins the CEL goes off again. This time though its code 5. MAP sensor code.
What is the difference in these map codes?
Old Jan 25, 2007 | 06:00 PM
igotthaspirit's Avatar
Default Re: Difference between code 3 & 5 (93sidelsolvtec)
are your vacuum lines connected properly? Code 5 means theres something disconnected, but the sensor itself is ok.
Old Jan 28, 2007 | 08:41 AM
Default Re: Difference between code 3 & 5 (igotthaspirit)
ya thanks that was it.
Old Jan 28, 2007 | 11:58 AM
no prob
rfm98crv
Honda CR-V & Element
Sep 2, 2013 05:08 AM
Hanmin
11
Sep 30, 2010 10:35 AM
aptyk88
Oct 15, 2008 12:49 PM
Nextelbuddy
10
Jun 19, 2005 07:24 AM
Achenar
Oct 2, 2004 01:45 PM
