help needed bad..i just cant figure out what is wrong !!!
i have a few problems that occur and hopefully you all will be able to help. i am running as of now a saab t3 with dsm 450's and a resistor box. a tial with the small red spring a drag 3 front mount along with the uber chip for my b16. the car starts fine...runs fine but the vaccum is low at idle and cruising...its at 19hg/mm along with that the car bogs out badly when i hit about 5200rpm. im not sure whats up with that. then lastly i throw a code 14 (iac) and yet it does a cold idle fine and doesnt studder when cold. it does have a two step built into the chip which i found out after the fact at 3500rpm. please help. if you need more input feel free to ask. thanks guys so much in advance.
Re: help needed bad..i just cant figure out what is wrong !!! (delslow94)
I idle at 20 hg/in so thats not a big deal....maybe try cleaning your IACV out...if you have a code of it why not try that first?? You could possibly be going super rich right there??? Not too sure..need more info!!
Re: help needed bad..i just cant figure out what is wrong !!! (Ricey McRicerton)
i am thinking of playing with gapping tomorrow....im pretty sure we tried .30 on them but then again who knows what happened...i have had them not measure up when i double checked so that might be part of it. any suggestions on gap size. i have a blaster external coil if that helps. also my fuel pressure is at 41-42 static. do you think i should drop it some to around 38?
jamessh1
09-10-2008 07:12 AM
