Help me think this through - oil pressure readings using adapters
So I've been thinking here and I need your help to figure this out.
I have installed a Quad-Outlet oil adapter on my firewall for relocation of oil presure sensor. So one port from back of block to adapter. That leaves 3 ports open.
One port is being used by Stock oil pressure sensor ( namely for dummy light operation ),
one port is being used by Aftermarket AEM oil pressure sensor ( electric ),
and last port has a 1/8" NPT to -3AN adapter used for turbo oil inlet line.
Now my question is how accurate will my oil pressure readings be by my Aftermarket sensor at that location ?
Re: Help me think this through - oil pressure readings using adapters
I have also wondered this.. I did the same set up as you except i also had a line running to the head on ls vtec.
At first i did not have enough oil pressure to engage vtec. I had to put in a sandwich plate as well and run a separate line to the head.
But i have wondered if my gauge will be correct seeing as how the sender is sort of "in line" rather than at a dead end??
It should be "close enough" provided all your lines are large enough. It may be 5-10 psi off, but that's not really a significant number in the grand scheme of things.
You'll know if you have pressure at idle, and you'll see any significant drops that may happen due to a rapid pressure loss or other event.
My setup needs accurate oil pressure at idle more than anything. Past idle I'll be fine.
In my opinion its not a numerical reading that matters as much as knowing there is some kind of oil pressure. But once you have a base pressure figured out for your particular set up you should be able to spot any problems from that. Your not going to notice small changes while driving anyway.
I was worried about my oil pressure when i first finished my build (mine reads really low compared to what i have read it should be). I have a line coming off the back of my block that goes to the firewall with fittings for the stock sensor, turbo supply, and pressure gauge.
also, i think that having the feed line has the biggest effect on readings b/c as mentioned oil is flowing past the sensors, rather than "dead ending", i had a similar oil relocation on my first setup and never saw over 60psi at WOT, kind of worried me at first but then i realized it was getting a reduced reading from feeding the turbo
with a dedicated line with just the sensor, i see 80psi regularly
