Help me settle a stock block debate
Old Aug 22, 2011 | 05:53 AM
EdSales's Avatar
Default Help me settle a stock block debate
Alright, so me and a friend have been debating with each other for awhile about 3MM Headgaskets and Stock Blocks.
We both are looking to get 400 WHP out of our cars, but plan to go about it in 2 different ways. He believes that just adding a 3MM Head Gasket, and his car will be as reliable at 20LBs of Boost as a full built motor. He then argues that a fully built motor still has a 3MM Head Gasket.
My arguement is different. I've read that 3MM HeadGaskets are bad, due to the fact that it changes I beleive the Ignition time (?) because the distance the piston travels up has no been changed in relation to the head/valves? For 400 WHP, I will looking atleast a Piston change if I could get away with it, but will prolli end up picking up a sleeved LS Block and going from there.
Please add some input into this debate, and help me prove him wrong that jsut because he had 310WHP with a B16 Turbo'd CRX does not mean that a 3MM Headgasket and a BlockGuard is a full proof way to 400WHP that is reliable.
Old Aug 22, 2011 | 06:02 AM
joe111599's Avatar
Default Re: Help me settle a stock block debate
It just lowers your compression is all. I wouldn't run a 3mm head gasket. Stock engine with the 3mm head gasket is still a stock engine. Nothing close to a fully built motor by ANY means. The rods/pistons will let go just as easy as yours would with the stock head gasket. I don't know where he is getting his info from. lol
Old Aug 22, 2011 | 06:23 AM
dantamparacer's Avatar
on a stock honda block you should be safe at 400. I have seen a few cars make around 510whp with just pistons and rods, these motors have been running a few years. look at my sig that was completely stock internals, and lasted 8 months
Old Aug 22, 2011 | 08:41 AM
sanman000719's Avatar
stock block here and oem gasket well over 500whp
Old Aug 22, 2011 | 09:34 AM
jnv255's Avatar
Technically, they're all stock blocks, just sleeved
Old Aug 22, 2011 | 10:18 AM
SovXietday's Avatar
There are a million and a half different ways to make 400whp on a Bseries.
3mm headgaskets and blockguards are rather old school and often times do more harm than good. I wouldn't ever use a blockguard and I sure as hell wouldn't ever use anything but a Honda headgasket. But that's me and my 400whp Dseries. And no, my "built" engine doesn't have a 3mm headgasket because they are unnecessary and inferior to the Honda ones.
Where was I going with this? Oh, right. Your friend knows nothing about how engines work. That's all you really need to know, you're doing it the right way.
Old Aug 22, 2011 | 10:40 AM
civickiller's Avatar
hmm, i always thought stock hg's was 3mm. how thick are stock hg's just for my knowledge?
Old Aug 22, 2011 | 10:44 AM
kyden's Avatar
stock is .030" which is .762mm
Old Aug 22, 2011 | 11:12 AM
i knew there was a 3 in there somewhere lol. go e85
Old Aug 22, 2011 | 12:47 PM
SLIM NOTHING's Avatar
stock blocks are fine at your power, stop fighting around about headgaskets ans ****. use OEM HG, E85 as civickiller said, upgrade fuel system to where you have enough to support your power goal and e85. stock rods ands pistons are fine at your power.
Old Aug 22, 2011 | 01:35 PM
ok let me rephrase stock b18c1/crank/p72 pistons/blahblah blah everything wa like it was bought brand new
579@28psi
completey stock, and the block is still good after about 30 trips down the track
Old Aug 22, 2011 | 02:40 PM
racebum's Avatar
i understand the compression debate of the hg, but the actual strength of the b18c hg is beyond what the sleeves will ever take. it's 3 layers of stainless steel. the sleeves will distort and cause leakage way before that gasket comes apart. it would take just an insane amount of pressure for that gasket to actually come apart
Old Aug 22, 2011 | 02:55 PM
SovXietday's Avatar
Exactly, a thin, well made headgasket will not be subjected to anywhere near the pressures that a thick headgasket will. The nice thin surface area will keep you from blowing it out.
hYbRid_Eg6
Dec 27, 2009 10:40 PM
K7-1Ktrevor
Aug 24, 2009 03:40 PM
gettin it
Jun 30, 2008 05:26 AM
C4wrx
Aug 4, 2002 06:23 PM
DLB1994
Jul 3, 2002 01:48 AM
