20psi and these Wisecos
Old Nov 26, 2006 | 02:08 PM
HiProfile's Avatar
Default 20psi and these Wisecos
When I got my Wiseco pistons, I was excited until I pulled them from the box. I hope to make some decent numbers with my motor soon, and I'm afraid that the stamped-on numbers could eventually lead to detonation. The pistons I've seen in other people's threads don't have any letters on the piston's top, is this normal with Wiseco's?
(Click it to make it bigger)
There are also a lot more sharp edges than I'd have liked, should I round them all off? Its going to be for a 300-400whp D16, daily driven on 93 octane and CromePro. All the parts will be balanced soon, so removing material doesn't scare me.
Old Nov 26, 2006 | 02:14 PM
non-VTEC's Avatar
Default Re: 20psi and these Wisecos (HiProfile)
those are normal........thats how off the shelf wiseco pistons come.....
Old Nov 26, 2006 | 02:16 PM
StolenTeg's Avatar
400whp on a D-series on pump gas huh
Old Nov 26, 2006 | 02:18 PM
abnaasefmb's Avatar
Hi- you **** bitch! As soon as you start your motor those numbers will be covered by carbon build up , but if you must just put some rubbing compound on a cloth and rub them a little bit that will remove any microscopic sharp points, crackhead!
Old Nov 26, 2006 | 02:27 PM
drintegra's Avatar
Default Re: 20psi and these Wisecos (abnaasefmb)
this has to ba a joke right?
Old Nov 26, 2006 | 02:28 PM
HiProfile's Avatar
Default Re: 20psi and these Wisecos (StolenTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">400whp on a D-series on pump gas huh</TD></TR></TABLE>
Aim high! Seriously, who would be proud of saying "225whp built & boosted D16"? I always like "more with less", otherwise I'd have an LS1 'bird with a blower. I plan on running meth injection eventually if I go over 300, but I'd have to change turbos first. I also have access to E85.
Thats also why I'm '****' with this build, I plan to live near the edge of this motor's typical potential. The difference is that all oil passages are being enlarged, my oil pump's devcon is hardening as I type, and if my damn flywheel/clutch ever get here, it will be completely balanced. If I build the head, 9k may be feasable - safely.
The other reason I'm wary is all the CP pistons that melt the intake reliefs. Any leaking oil burning on any sharp edge will melt the piston in a high-strung D16 like its wax.
Old Nov 26, 2006 | 03:06 PM
abnaasefmb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">
The other reason I'm wary is all the CP pistons that melt the intake reliefs. Any leaking oil burning on any sharp edge will melt the piston in a high-strung D16 like its wax.</TD></TR></TABLE>
no that **** is from lean burns! and why are you enlarging your oil lines
Old Nov 26, 2006 | 04:29 PM
Garage 808 Hatch's Avatar
i always rub the tops of the pistons with green scotch brite to knock down sharp edges and stamped writing
Old Nov 26, 2006 | 04:34 PM
not2slo128's Avatar
Default Re: 20psi and these Wisecos (Garage 808 Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">stamped-on numbers could eventually lead to detonation</TD></TR></TABLE>
Why would that cause detonation?
Old Nov 26, 2006 | 04:38 PM
ccivic's Avatar
Default Re: 20psi and these Wisecos (not2slo128)
I've never seen a problem with Wiseco's.. CP's have the problem because the metal between the intake valve relief and the edge of te pisto is SOOOOOOO thin.. Wiseco's have some meat in there.
Old Nov 26, 2006 | 04:42 PM
HiProfile's Avatar
Maybe I should put it another way - I'm 'massaging' all the major oil passages inside the block. No restrictions, no 90* mitter turns - smoothed the way it should be. Its usually expected a completely OEM setup will turn 8k w/o oil issues, over that your running a big risk due to the pump design. Smoothing the flow will help keep the pump from falling on its face, per se.
Old Nov 26, 2006 | 06:16 PM
shortyz21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Maybe I should put it another way - I'm 'massaging' all the major oil passages inside the block. No restrictions, no 90* mitter turns - smoothed the way it should be. Its usually expected a completely OEM setup will turn 8k w/o oil issues, over that your running a big risk due to the pump design. Smoothing the flow will help keep the pump from falling on its face, per se.</TD></TR></TABLE>
so your saying the guys running 10 000 rpm all motor setups. are "massaging" their oil passaging. and devconning their oil pumps?
put the pipe down
Old Nov 26, 2006 | 06:30 PM
Muckman's Avatar
Moderator in Chief
Do you think a high end piston company would manufacture thousands of pistons that have a critical detonation causing flaw? No. If they did, they'd be out of business.
Old Nov 26, 2006 | 06:38 PM
fast2camciv's Avatar
Default Re: 20psi and these Wisecos (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">
put the pipe down</TD></TR></TABLE>
its a d-series thing (im assuming y8) so most wouldnt understand...im also assuming that you are doing all the endyn mods to the pump and what not? i did them all on my y8 block and got favorable results. 400whp on pump is prolly not going to happen...why risk it???? 300whp is PLENTY on the street...more than a fwd was ever supposed to handle...you want more? put some race gas in it lol...i ran my car for 4 months straight on 110 leaded (we have it at the pump here in potato land)
Old Nov 26, 2006 | 07:13 PM
HiProfile's Avatar
As fast2camciv said, its a d16 thing, but more specificly a d16y8 thing.
Muckman, If you knew how much bad luck I've been having for the last 24 months, you'd be just as suspicious as me.
AFAIK, susgestions that are followed up by pictures and set-priced services to do said moddifications on the Endyn website aren't just guesses and maybe ifs. They come from years of trial/error. If they can make a 430whp supercharged daily parts driver using a D16 - and have it last 5+ years - then I tend to trust what they say.
fallbacdun
K Series
Oct 25, 2010 04:58 AM
narfdanarf
Aug 7, 2009 02:50 PM
DEMNTD1
Feb 22, 2006 03:39 PM
