HELP with DSM injector wiring
I'm looking into wiring up my DSM blue top 450cc into a 99 civic si, which is OBD II I can only find it for OBD I or the links don't work anymore is someone can point me into the right direction that would be great i havwe spent the last 1 1/2 looking could not find, thanks
You can use the same concept as the OBD1 install. There is a dead end plug on OBD2 cars as well. You can use that to wire in the resistor box.
It is by the master cylinder. All the wires are yellow and black. You use a multimeter and check continuity between the plug and your injectors.
There are like 5-6 wires in that dead end plug and 4 of them go to your injectors. You just have to find out which ones. You put one probe on the injector plug and one in the dead end plug and find which ones match up.
This is the easyist way to do it go to a local junk yard and pick up the connectors for an Obd 1 honda injectors and just cut your plugs and hook up the ones from the OBD1 and that is it your good to go. I have done it plenty of times and it has worked for me.
carlos8
Engine Management and Tuning
Mar 25, 2014 09:23 AM
Rus1an
May 18, 2007 08:51 AM
integranator
Apr 7, 2003 06:59 PM
