GT32?
Old Jan 31, 2006 | 05:28 AM
blackpearlcivic's Avatar
Default GT32?
I saw this turbo GT32-73TRIM-78AR butt i wanna now how much hp this turbo could make??And how this whil spool on a 2.0L LS/VTEC.I hope someone can tell a few details off this turbo because this turbo is fits right in to my budget.
Old Jan 31, 2006 | 07:15 AM
ValleySyder's Avatar
Default Re: GT32? (blackpearlcivic)
600hp... it will spool like yesterday .. on a 2.0 ls vtec
Old Jan 31, 2006 | 10:01 AM
Default Re: GT32? (ValleySyder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ValleySyder &raquo;</TD></TR><TR><TD CLASS="quote">600hp... it will spool like yesterday .. on a 2.0 ls vtec </TD></TR></TABLE>
Are you sure that this turbo can make that kind off power??
Old Jan 31, 2006 | 10:46 PM
Nobody else nows a few details about this turbo??
Old Feb 1, 2006 | 02:54 AM
D-tuned's Avatar
contact the shodan on here. he will be able to tell you everything you need to know about that turbo. I had him do a custom spec'ed GT32 base turbo for me. numbers in my sig will new numbers to follow
Old Feb 1, 2006 | 06:16 AM
Benjithx's Avatar
Default Re: GT32? (D-tuned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ValleySyder &raquo;</TD></TR><TR><TD CLASS="quote">600hp </TD></TR></TABLE>
No..
more than likely 400hp give or take
Old Feb 1, 2006 | 07:55 AM
Oyvind Ryeng's Avatar
600 (B?)HP, that's rich. The largest compressor wheel that one comes with from Garrett is the dinky 71 mm. we know from the GT2871R. Garret specs it at 420 (B?)HP max.
Old Feb 1, 2006 | 07:59 AM
Default Re: GT32? (Benjithx)
2.0 ls vtec gt3255S did 513 whp @ 23 psi on pump gas.... injectors max'd out or else 600 was reachable with a better IM and cams at higher boost level .. since the turbo your speakin of is a 73 trim maybe more.. but check precisionturbo.net.. they have a chart on the GT32 ...and what trims and a lot more info ...
Old Feb 1, 2006 | 08:07 AM
EGRhatch's Avatar
Default Re: (Oyvind Ryeng)
I have one custom built... precision, TO4E .63A/R going to the flow guy today, came off a porsche 911 Twin Turbo... after about 80miles, guy got larger turbos... but I will let you guys know the power when it gets back to me.
but on the porsche 3.2L they spooled up at 3400RPM so whoever knows how to do the math to figure out when they would spool up on a 1.6, 1.8, 2.0 that should give you an idea...
hope that helps... but with these 2 turbos he put down a little over 800 at low boost...
sonne7126
Oct 3, 2006 08:21 PM
Keangdawizes
Jun 9, 2005 05:50 PM
my ride
Apr 21, 2004 01:28 PM
JDMVTEC
Oct 13, 2003 08:47 AM
Integra717
May 19, 2002 11:22 AM
