help detenation on my b20
Old Jun 3, 2003 | 10:43 PM
TURBO B's Avatar
Default help detenation on my b20
ok peeps this is what i have 99 b20z drag turbo kit AEM fpr walbro 255 intank vortec fmu thats what i got for fuel ok now i just took off the delta gate and put on a tial 35 mm turned the boost up to 9 psi and now i detonate what could it be from oh and i have not touched my timing could it be because of stock timing please help thanx
Old Jun 4, 2003 | 04:46 AM
b20turboic's Avatar
Default Re: help detenation on my b20 (TURBO B)
you are nuts for boosting the honda glasshouse motor without managment first of all .. and yes if you have just an fmu its your timing and id run colder plugs to get the spark further away from your block ... that way it takes more heat to thereticly detonate but who knows.. im running Zdyne Gold with 450cc's (same as hondata4B and 440's basicly) and im going to put it on a dyno at 14 so its all in tuning with these honda's so save up for managment (my .02) and as for 9psi turn it down even with a timing change and plugs it will most likely break nothing untuned seems to last ..
Old Jun 4, 2003 | 10:12 AM
TURBO B's Avatar
i have 1 degree colder plugs sorry i forgot to say that
Old Jun 4, 2003 | 11:01 AM
TURBO B's Avatar
Default Re: (TURBO B)
ttt
Old Jun 4, 2003 | 11:08 AM
AlLMoToRvOtEr's Avatar
Ya try runing colder plugs and retarding your timing alitte bit, also try turning up your FPR.
Old Jun 4, 2003 | 11:15 AM
keebler65's Avatar
Default Re: (jdmhatch138)
dont you have an air/fuel ratio guage? if so what are your numbers like?
Old Jun 4, 2003 | 12:53 PM
TURBO B's Avatar
i have the autometer air/fuel and it goes rich then as soon as i get in boost for a sec it goes lean and starts to detonate
Old Jun 4, 2003 | 01:01 PM
TeStUdO's Avatar
how do you know you are detonating? do you hear it? turn back the timing
Old Jun 4, 2003 | 01:10 PM
TURBO B's Avatar
yes i can hear it
Old Jun 4, 2003 | 04:34 PM
jdmhatch94's Avatar
bump
Old Jun 4, 2003 | 05:18 PM
boosted92's Avatar
Default Re: (jdmhatch94)
Get an MSD BTM and use it to pull back a little bit of timing, untill you stop getting detonation, or put better gas in it.
Old Jun 4, 2003 | 07:18 PM
escocrx's Avatar
Default Re:
dont go offa those a/f gauges. they are so inaccurate. if yer tryin to tune with that theres your problem
i'll let the post back to helpin u instead of talkin **** hehe. sorry
Old Jun 4, 2003 | 08:04 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Re: (escocrx)
Dude run as high octane as you can get @ the pump and pull a few degrees of timming and turn down the boost. Your gonna break someting unless you get it tuned...
good luck
Blaze
Old Jun 4, 2003 | 08:19 PM
TURBO B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by escocrx &raquo;</TD></TR><TR><TD CLASS="quote">dont go offa those a/f gauges. they are so inaccurate. if yer tryin to tune with that theres your problem
i'll let the post back to helpin u instead of talkin **** hehe. sorry</TD></TR></TABLE>thats fine man im goign to get that split sec air fuel gauge
Old Jun 4, 2003 | 08:41 PM
drvfast's Avatar
what kind off injectors are u running?
Old Jun 4, 2003 | 09:09 PM
hybridsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBO B &raquo;</TD></TR><TR><TD CLASS="quote">i have the autometer air/fuel and it goes rich then as soon as i get in boost for a sec it goes lean and starts to detonate</TD></TR></TABLE>
WTF? do you have any fuel managment at all? The stock a/f gauge is not accurate, but it still works. There is NO WAY it sould be in the red/yellow section when in boost. The idea of a WB is that it will show the difference between 12.0 and 13.0, not 17.0 ot 13.0...
Make sure you fuel adder is working, it sounds like it's not...
Old Jun 5, 2003 | 02:57 AM
TURBO B's Avatar
stock injectors
Old Jun 5, 2003 | 02:58 AM
TURBO B's Avatar
i pulled the timing back no mor detenation but it goes a little lean
Old Jun 5, 2003 | 09:31 AM
TURBO B's Avatar
bump
walrus_07
Oct 25, 2011 11:16 AM
ItzTw
Oct 17, 2003 05:38 PM
hybridb18
Jan 10, 2003 10:48 AM
khang77642
Jun 10, 2002 12:16 AM
Sh4rky
Apr 2, 2002 01:34 AM
