Timing and sparks plugs ..... help.....
Old Oct 24, 2011 | 01:07 PM
walrus_07's Avatar
Default Timing and sparks plugs ..... help.....
Dose anybody know what I should gap my spark plug and what spark plugs to buy Also how many*degree do I set my timing back to.The motor is a 96 ls and I'm runing 8 psi and the turbo is a evo 10 turbo and what should the*fuel ratios *be at.
Old Oct 24, 2011 | 03:03 PM
93supercoupe's Avatar
Default Re: Timing and sparks plugs ..... help.....
brk7es and 22-25 thousands.
that NGK part number might be off a lil bit, but if you search you will find it.
Old Oct 24, 2011 | 03:09 PM
walrus_07's Avatar
Can I run NGK 6 and what do I set the timing at and what should the fuel reading be at
Old Oct 24, 2011 | 03:11 PM
16 degrees base timing, under 12.0 in boost for ratio readings, and 6's are too hot.
Old Oct 24, 2011 | 04:28 PM
walrus_07's Avatar
I'm useing a fmu so dose that change anything
Old Oct 24, 2011 | 04:31 PM
LightningTeg's Avatar
Community Builder
lol
Old Oct 24, 2011 | 04:41 PM
V-SPEC 1's Avatar
Ngk4644 is the part # for the 7's
Old Oct 24, 2011 | 05:06 PM
walrus_07's Avatar
So then leave the timing at 16 degree and gap the spark plug 22-25 right
Old Oct 24, 2011 | 05:12 PM
you might wanna retard it a couple degrees if your using a FMU.
Goto xenecron.com and buy a chipping kit and basemap for like 50bux and ditch the fmu.
Old Oct 24, 2011 | 07:04 PM
walrus_07's Avatar
So set the timing back to 12-13 degree and gap the spark plug like 22-25 and fuel ratio should be around 12.00 in boost right or am I missing anything.
Old Oct 24, 2011 | 09:02 PM
Spawne32's Avatar
8psi LS, 23degrees of timing (at WOT), 20 degree base timing, ZFR6FGP
Old Oct 24, 2011 | 09:16 PM
Spawne32's Avatar
oh and i have my distributor timing set to 16 degrees, my dynamic timing is set to 20 at idle via ectune
Old Oct 25, 2011 | 02:04 AM
7rrivera7's Avatar
WOT run right? Looks perfect!
Old Oct 25, 2011 | 03:05 AM
blackeg's Avatar
Haha yes it does. Since you are living in 2003 you might want to upgrade to uberdata, I hear its the new craze and will have tons of support and updates. Also get on moates.net I hear he has this new burner called tha burn1.
( I actually still have my burn1 and it works flawlessly 7 years later)
Old Oct 25, 2011 | 06:56 AM
Community Builder
Distributor should by synced to ectune via ignition lock routine and a timing light.
Old Oct 25, 2011 | 07:34 AM
Spawne32's Avatar
edit: nevermind, i set it via the service connector
Old Oct 25, 2011 | 07:57 AM
Community Builder
ALL MOTOR always told me to leave it at 16 degrees :/
Well you sync it to 16 degrees. The ecu is constantly changing timing at idle. You lock it in ectune so the ecu stops changing it and you can properly time the engine via the dizzy only.
If you throw a timing light on the engine normally you'll notice the marks on the pulley bouncing around as the ecu is messing with things.
Old Oct 25, 2011 | 08:03 AM
Spawne32's Avatar
ah, that would explain a couple issues ive been having, looks like ill be breaking out the timing light today
Old Oct 25, 2011 | 08:06 AM
Community Builder
The routine is under tools/ignition lock or something
Old Oct 25, 2011 | 08:09 AM
Spawne32's Avatar
yep, i know exactly where its at lol always wondered what it was
Old Oct 25, 2011 | 08:33 AM
walrus_07's Avatar
So this what I'm going to doing 8 psi on the evo10 turbo using a Jackson racing fmu till I have the money for a tune. fuel ratio are going to be 12.50 wot and for plugs I'm running NGK 7 gap to 28 and timing set at 13 degrees is that going to work.
Old Oct 25, 2011 | 08:38 AM
Spawne32's Avatar
i found that the 7 range plugs were too cold on my 8psi JRSC setup, remember, LS engines start with a plug heat range of 5
Old Oct 25, 2011 | 09:12 AM
walrus_07's Avatar
So what plugs should I get then
Old Oct 25, 2011 | 09:14 AM
Community Builder
Get 7s. You'll be making alot more power then him. Also aim for 11.5 AFR to be safer.
Old Oct 25, 2011 | 09:36 AM
Spawne32's Avatar
i made a mistake lol reason i didnt use the sync was because i set it with the jumped connector, that was my error
