ENGINE assembly help
Old Jun 5, 2003 | 08:06 AM
senpai's Avatar
Default ENGINE assembly help
Quick easy questions:
1. Do I apply assembly lube all over the bearings then install them? (clearances will or have been checked)
2. I need torque specs for ARP rod bolts for B18B rods.
Thanks
Old Jun 5, 2003 | 08:13 AM
b18bturbo's Avatar
Default Re: ENGINE assembly help (maztur)
what rods are you using and what arp rod bolts. custome age 625+ or arp2000 which models are you running with
yes you coat the aseembly lube on the bearings
Old Jun 5, 2003 | 09:10 AM
senpai's Avatar
Default Re: ENGINE assembly help (b18bturbo)
OEM LS rods with the ARP rod bolts; the rod bolts were already on so I have no idea which one it is. It just says ARP on the bolt. Let's just assume they are the cheapest ones.
Old Jun 5, 2003 | 09:15 AM
b18bturbo's Avatar
you really need to find out which bolt it is everyone has different strech rating.
most of them that come with the ealge rods are 28 ft lbs arp 2000 bolts
Old Jun 5, 2003 | 09:17 AM
senpai's Avatar
What's the diff between the two types? I bought these rods with the rod bolts already on so I have no idea.
Old Jun 5, 2003 | 09:18 AM
b18bturbo's Avatar
some are strong than others if you torque it incorrectly they could stretch and damange your motor
Old Jun 5, 2003 | 09:22 AM
BlueSi2k's Avatar
no lube on the underside of the bearings correct?
Old Jun 5, 2003 | 09:34 AM
senpai's Avatar
That plain out ******* sucks; do you know the torque specs I would use for each one on OEM LS rods?
Oh yea, the oil hole faces intake side, correct?
rich7777
Mar 1, 2010 07:43 AM
LSVtechnologytur...
Jul 14, 2008 07:39 AM
neyrod
Feb 16, 2005 11:05 AM
TURBL0W
Dec 1, 2004 06:23 PM
