HELP!! BOV NOT OPENING
Old Mar 17, 2005 | 08:38 AM
_SHIFT's Avatar
Default HELP!! BOV NOT OPENING
I need some help. I just got all of my turbo set up done. but the first time i went out to drive it, the bov wouldnt open up at all. Its an obx universal bov and it said its adjustable, but i dont know how to adjust it and it is def not working. I need to knwo who to get it to work asap. Thanks.
Old Mar 17, 2005 | 08:49 AM
PM-Performance's Avatar
Default Re: HELP!! BOV NOT OPENING (1992vxhatch)
i know it sounds stupid but did you run a vac line to it. ? how much boost were you running when it didnt open?
stupid, but could deff be related if something was overlooked
Old Mar 17, 2005 | 08:52 AM
_SHIFT's Avatar
Default Re: HELP!! BOV NOT OPENING (itr206)
yep vac line is on it and im runnin only 7 psi right now untill i can get it tuned for a little higher.
Old Mar 17, 2005 | 08:57 AM
if you take the BOV off and try and push it open , will it open? Could have some surface rust or something or something sticking. If it doesnt open by hand, maybe spray some lube in there and loosen some **** up in there
Find the adjustability of it though. If there is no **** or screw it might need washers or lack of
Old Mar 17, 2005 | 09:01 AM
_SHIFT's Avatar
I can push it up on my own, and i have washers for it but where do they go?
Old Mar 17, 2005 | 09:02 AM
post a pic of it?
I think with like the Turbo XS style ones you take off the top of the BOV and put the washers over the spring and thne put the top back on?
I dunno for sure though. I never had one like that.
Old Mar 17, 2005 | 09:08 AM
_SHIFT's Avatar
wouldnt addaing more washers make it harder to open?
Old Mar 17, 2005 | 09:22 AM
i think so. is there washers in it already then?
were you boosting the full 7psi and didnt hear it?
Old Mar 17, 2005 | 09:31 AM
_SHIFT's Avatar
no there arnt any washers in it at all. and i doubt i was going all 7psi just like half/.75 throttle.
Old Mar 17, 2005 | 09:32 AM
get on it hard at full boost and let off and see if it opens.
If the boost is not high enuff to really open it, then thats what the prob could be. 4-6psi isnt gonna make it loud
Old Mar 17, 2005 | 09:34 AM
_SHIFT's Avatar
yea, but it should have opened up some ya know...but there was nothing..
Old Mar 17, 2005 | 09:45 AM
but if its only at partial low boost you might not hear anything over your exhaust and turbo spooling.
Old Mar 17, 2005 | 10:23 AM
quicksol95's Avatar
do you have it teed off are you running it str8 to the intake manifold
i guess the real question is how do you have the vaccum lines?
slide inside
Sep 24, 2009 08:40 PM
superslow-oto
Oct 27, 2007 05:34 PM
boosted_duece
Nov 23, 2005 09:29 PM
FOrSfEd
Mar 28, 2004 09:16 AM
JustAnotherHonda
Feb 13, 2003 05:39 AM
