Headgasket..Compression. can i do it?!
Old Feb 27, 2009 | 07:29 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Headgasket..Compression. can i do it?!
hey guys, currently i have 11:8 wiseco pistons on eagle H-beam rods in my gsr..
i plan on turboing it next month, question is. Would I be able to buy a thick headgasket to lower my compression enough to be able to boost it? I'm lookin at putting 300-350 whp to the ground. With that power level, would my pistons,compression and a thick headgasket be okay to do? Taking in that many guys with stock GSR blocks put a thick headgasket in and put down 350+ whp..
Yes I understand it's cutting a corner, but if it can be done fine i'll try it out..
please no thread whoring... i know in a way this is sort of a bad idea but i'm seeing if it's plausible
Old Feb 27, 2009 | 07:40 PM
Garcia-Racing's Avatar
Default Re: Headgasket..Compression. can i do it?!
Assuming it's stock bore you'd have to run like a 0.080" headgasket to bring it down to flat tops compression. Gonna burn pretty funky, but I guess it can be done.
Old Feb 27, 2009 | 07:54 PM
EARLdaSQUIRREL's Avatar
official honda whore
even if you get it down to 11:1 it would be better
Old Feb 28, 2009 | 10:32 AM
the block has stock sleeves, it's bored to 81.5 with a block guard, the hot tanking and bore-ing was done after the guard was installed so it was seated right..
but with a 300-350whp power level, would i run a big risk of blowing out a .080 headgasket?
Old Feb 28, 2009 | 10:36 AM
with a 0.060 headgasket, the zeallot's calculator said i'll be around 10:8-11:2 with my compression right now..
i think i'm gonna give it a try and see what happens, would my high comp pistons will it not burn efficient in the combustion chamber?
o0o_tylor_o0o
Dec 7, 2010 07:03 PM
HarfordCTR
Dec 21, 2007 07:06 PM
digital sol
Jan 20, 2006 03:27 PM
GSRerrr
Apr 4, 2005 07:11 PM
wrXtian
Oct 17, 2002 10:16 AM
