headgasket
Old May 9, 2007 | 11:58 AM
A.S.I.M.O's Avatar
Default headgasket
what is the difference in headgasket thickness'
i want to run a copper headgasket for my car.
and they have diffent thickness' ranging from 0.8mm to 3.0mm
what would be the difference with going thicker vs thinner?
Old May 9, 2007 | 03:09 PM
A.S.I.M.O's Avatar
Default Re: headgasket (A.S.I.M.O)
bump. i know someone knows something.
Old May 9, 2007 | 03:10 PM
jdizzle!
Guest
Posts: n/a
compression
Old May 9, 2007 | 05:16 PM
NJIN BUILDR's Avatar
Why do you want to run copper?They work ok in a race application but can be a little finicky sealing water.If you can use a mls gasket than do that.I would only use a copper gasket if there was no other alternative.
Old May 9, 2007 | 07:12 PM
A.S.I.M.O's Avatar
Default Re: headgasket (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Why do you want to run copper?They work ok in a race application but can be a little finicky sealing water.If you can use a mls gasket than do that.I would only use a copper gasket if there was no other alternative.</TD></TR></TABLE>
well i was told it would be better for my application because i have a 1.3 dohc swift gt running over 20 psi. but i was probably going to turn it down and run around 15-17 psi. if i am running more than 20 then i would do it. but i wanted to know the diffence in thickness'
Honda Motorcycles
11
Jul 2, 2007 03:19 AM
Inline6 Silvia
Oct 30, 2006 08:37 AM
ssrcx94
Dec 18, 2005 10:05 AM
jdm_redneck
11
Mar 16, 2004 09:37 PM
Westrock2000
Feb 15, 2003 01:00 AM
