Using a liquid gasket with a headgasket?
Old Feb 14, 2003 | 03:18 PM
Westrock2000's Avatar
Default Using a liquid gasket with a headgasket?
Well I tried to use the 2 layer OEM gasket to try and make the compression a little higher, but I don't think it's sealing correctly. So, this spring break I'm gonna take her apart and put a new unaltered one on. My question is, is there anything I can put on the headgasket to help it seal better. Like a copper paste or anything? Just wanna make sure it seals real good next time.
Old Feb 14, 2003 | 05:07 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Using a liquid gasket with a headgasket? (Westrock2000)
you can use a copper spray or the can that comes with the stick in to apply like a paste. get it at your local auto parts stores.
Old Feb 14, 2003 | 06:13 PM
deepgreengsr's Avatar
Default Re: Using a liquid gasket with a headgasket? (MotorMatrix.com)
I put the copper spray on a porsche motor once. works
Old Feb 14, 2003 | 07:29 PM
Default Re: Using a liquid gasket with a headgasket? (deepgreengsr)
Cool thanks...so this stuff will help seal real good?
Old Feb 15, 2003 | 01:00 AM
NirSpec1's Avatar
hey man
just use the copper gasket spray, I use it on all b20 and ls vtec setups. A buddy of mine has also used it at the track with a blown head gasket. Took the head off and copper sprayed the **** out of the blown gasket and then made 3 more passes without any problems.... so I would use it for any sealing probs.
peace
crx-neo
Nov 6, 2005 10:16 AM
eh2-hb
Oct 13, 2005 10:01 PM
DriveSlowHomie
Apr 1, 2005 04:37 AM
zCivic
Jan 11, 2003 12:35 PM
94gsr
Sep 12, 2002 11:37 AM
