Head gasket problem?
Old May 9, 2013 | 06:40 PM
alex1320's Avatar
Default Head gasket problem?
So for the last couple if days my cars been blowing white smoke. I figured it was coolant but didn't smell like it. Just smelled like vapor. No overheating issue either so I pulled my down pipe off and there was all milky tan stuff in down pipe and exhaust which would lean towards a hg. Kinda lost cause I started my car without the down pipe off and didn't blow smoke at all? Can Any body help me out
Old May 9, 2013 | 07:58 PM
TheShodan's Avatar
Moderator
Default Re: Head gasket problem?
Make a small video with your mobile phone or good resolution camera. That will help before any further diagnosis can be made. please also make sure you describe what you've already done so far to combat the issue, as well as what you did BEFORE this issue started. Otherwise, unfortunately, your inquiry won't go too far here.
Old May 9, 2013 | 08:03 PM
xile6's Avatar
Pix.
It could very well be oil and water mixing in the exhaust and blowing out.
Old May 9, 2013 | 08:26 PM
bufalo123's Avatar
check your oil cap and if it looks like this then your got a headgasket problem
Old May 10, 2013 | 06:32 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
This MIGHT be true if it wasn't a turbo car...
OP - You gave us NOTHING to go off of. If your turbo has coolant lines the center section could be cracked. Is your resivoir bubbling? There is just WAY too little information to help you.
Old May 10, 2013 | 05:01 PM
alex1320's Avatar
right before this happened my turbo seals blew out. i pulled of the ic piping and there was oil in it. i replaced the turbo and was blowing white smoke ever since. sorry for not giving more info
Old May 11, 2013 | 01:36 PM
fukenboostin's Avatar
Well you just answered your problem.. Your turbo seals blew.. Oil and or coolant went through the hot side as well.. You didn't clean the dp out and that's what's smoking.. Clean the exhaust out and then try it
Old May 11, 2013 | 01:58 PM
alex1320's Avatar
ok thanks im cleaning out my exhaust today
DRoylflush
11
Apr 10, 2011 02:11 PM
highrollers23
Sep 2, 2009 06:54 PM
mannydhanju
Feb 21, 2009 09:33 PM
sailingstu05
Aug 20, 2008 11:08 PM
djviet2000
23
Apr 29, 2008 09:36 PM
