Head gasket for ITR, block guard?
Old Jul 1, 2004 | 02:01 PM
TypeR0186's Avatar
Default Head gasket for ITR, need block guard?
2001 ITR. will turbo'in it soooon. Im getting the head gasket for sure but the question is "do i need a block guard?" heard mix reviews about it, don't know which way to go. do they work? my goal is maybe 10psi max (track) and 7psi daily. thx and i got AEM ems
Modified by TypeR0186 at 3:34 AM 7/2/2004
Old Jul 1, 2004 | 02:16 PM
snailpoweredEK's Avatar
Default Re: Head gasket for ITR, block guard? (TypeR0186)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR0186 &raquo;</TD></TR><TR><TD CLASS="quote"> thx and i got AEM ems </TD></TR></TABLE>
Stock sleeves? I don't think the block guard is really necessary. Some people use them, some people don't. With the AEM EMS you should be fine without a block guard. I'd save the money for dyno time. Need more info than just 7-10psi, what size turbo are you going to use? And what Head gasket are you talking about?
Old Jul 1, 2004 | 06:30 PM
TypeR0186's Avatar
Default Re: Head gasket for ITR, block guard? (snailpoweredEK)
yep stock sleeve too. head gasket i don't know just any brand to lower the compression down. turbo size is any of the precision t3/t4 line. sc34, sc44, sc52? any size suggestion? i will have RC injectors also, around 600 cc maybe.
Modified by TypeR0186 at 8:15 AM 7/2/2004
Old Jul 1, 2004 | 07:11 PM
Chris F's Avatar
My tuner talked me out of a head gasket, why take the motor apart while it still works.
Planning on 8 PSI on my stock motor ITR... will be done in a couple of weeks!
Good luck anyway. What are your HP goals? I'm thinking 250-275 for mine. Will hopefully keep track reliability with an oil cooler and fluidyne radiator.
edit:
Oh, and I'm getting the Greddy kit with an intercooler and Emanage, profec B.. I will probably start with the 310 CC injectors that the kit comes with. :-o
Old Jul 1, 2004 | 11:17 PM
TypeR0186's Avatar
Default Re: (ccfries)
my HP goal for this setup is around 275. thermal 3in or custom 3in with apexi N1. well i don't think is that bad to change out the head gasket. you don't need to take the hole motor apart just the head, not to bad. just to be on the safe side it's worth it i think.
Old Jul 2, 2004 | 12:38 AM
CTRbOy's Avatar
Default Re: (TypeR0186)
got a block guard and cometic headgasket for ITR to lower compression
Old Jul 2, 2004 | 08:17 AM
TypeR0186's Avatar
Default Re: (itrboy)
how much? brand?
Old Jul 2, 2004 | 10:52 AM
CTRbOy's Avatar
cometic and STR
Old Jul 7, 2004 | 03:53 PM
Circuit Star-29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snailpoweredEK &raquo;</TD></TR><TR><TD CLASS="quote">
Stock sleeves? I don't think the block guard is really necessary. Some people use them, some people don't. With the AEM EMS you should be fine without a block guard. I'd save the money for dyno time. Need more info than just 7-10psi, what size turbo are you going to use? And what Head gasket are you talking about? </TD></TR></TABLE>
And what does the AEM EMS and a Block Guard have to do with each other? I say go Hondata for tuning and if you don't plan on running more than 15 psi, don't bother with the block gaurd.
Old Jul 7, 2004 | 04:19 PM
hulkhb's Avatar
Default Re: (nathan atwell)
if you plan on running 7 psi daily you dont need the headgasket at all. I am running 7.5 psi and its perfect, you get great spool times (pending on how large the turbo is) and crazy top end.
dantamparacer
Apr 17, 2012 07:37 PM
92HB_HB
Sep 12, 2005 09:28 PM
WREKONIZE V8 KLR
Apr 6, 2005 10:40 AM
hondafanatic1
Feb 19, 2004 05:35 AM
TeamCracka
Feb 16, 2004 06:34 PM
