having problems with boostin high. please help
Old Sep 11, 2003 | 08:35 PM
joe pagolac's Avatar
New User
Default having problems with boostin high. please help
i have a gsr engine with a fmax kit. some reason i can't boost past 13lbs. any suggestions. thanks
engine
B18c1 with fully built block cept crank
JE 9:0:1 compression
crower rods
walbro fuel tank
aem fuel rail
3 bar map sensor
rc 550cc injectors
darton sleeves
crower valve train
JG intake manifold
fmax turbo kit
tial wastegate
greddy bov
apexi n1 exhaust
apexi power fc
Modified by joe pagolac at 9:59 PM 9/11/2003
Old Sep 11, 2003 | 08:36 PM
New User
Default Re: having problems with boostin high. please help (joe pagolac)
also have 3bar map sensor too forgot to add.
Old Sep 11, 2003 | 08:46 PM
Full-Race Henry's Avatar
use a boost controller or get a different wastegate spring.
Old Sep 11, 2003 | 08:49 PM
New User
Default Re: having problems with boostin high. please help (EF8_Fan)
i have a boost controller too already forgot to mention. already tried a different spring rate didn't help out. even when i'm boostin 13lbs i look at the gauge and its not consistent, the power drops and goes back up again. weird
Old Sep 11, 2003 | 08:57 PM
New User
i talked to the tuners already too and they said the only problem they see is the turbo is small, but i don't think thats it. the turbo was intentionally meant for an si but does that has to do with the restriction on high boost.
Old Sep 11, 2003 | 10:38 PM
the turbo you have should be a t3t4 if its an fmax. you should be able to boost a lot on that. anyway check how your vac lines are all hooked up to the boost controller and make sure your boost gauge is acurate. try different spring rates too,
Old Sep 12, 2003 | 06:59 PM
New User
vac lines are all connected and tried higher spring rate also didn't help out.
Old Sep 12, 2003 | 10:03 PM
grndcont's Avatar
i've seen cat's that get melted shut from turbo's witch can limit boost.
Old Sep 13, 2003 | 06:08 AM
EK_vzla's Avatar
set ur downpipe 3" .... i see that problem.....set ur downpipe 3" and finish not 13psi wall
Old Sep 13, 2003 | 06:17 AM
scatuli's Avatar
Default Re: (ARAXIS)
if you have the turbo xs boost controller check the direction of the V, it must be facing to the vacuum source
Old Sep 24, 2003 | 03:34 PM
New User
Default Re: (scatuli)
no its a greddy boost controller? i don't get what you're saying axxais
Integra Type-GSR
Jul 7, 2011 05:17 AM
jdm_phunk
Apr 8, 2011 09:29 PM
shabam
Jun 6, 2009 09:57 AM
doberwing
Apr 5, 2004 07:45 PM
HotRodTeg
Oct 28, 2002 08:43 AM
