HONDATA + 5BAR MAP?
Old Jul 14, 2004 | 05:29 PM
sfwdcivic's Avatar
Default HONDATA + 5BAR MAP?
i wanted to know if you can use hondata and a 5bar map. i have a friend and it has come the time to boost over 28lbs.
Old Jul 14, 2004 | 08:08 PM
TheShodan's Avatar
Moderator
Default Re: HONDATA + 5BAR MAP? (jkjb16a)
No, due to the voltage signal that is being read differently. Hondata will ONLY use the 3 Bar map sensor. Not 2 Bar, or 5 Bar....
AEM EMS, however, can use different bar map sensors for their hardware..
Old Jul 14, 2004 | 09:02 PM
PureTeg420's Avatar
Default Re: HONDATA + 5BAR MAP? (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">No, due to the voltage signal that is being read differently. Hondata will ONLY use the 3 Bar map sensor. Not 2 Bar, or 5 Bar....
AEM EMS, however, can use different bar map sensors for their hardware..</TD></TR></TABLE>
Hondata can read 3 bar and 2 bar, but not 5 bar. If hondata couldn't read 2bar, than no one with a stock map sensor would be able to run hondata.
Old Jul 14, 2004 | 09:44 PM
boosted hybrid's Avatar
Hondata can run the 5bar map sensor. All the vacuum columns remain the same as with the 3bar option enabled, but the boost columns are not what they are labeled in the software. The boost columns are spread out further apart i.e it doesnt go 4psi, 8psi, 12psi, 18psi, 24psi, 28psi...its more like 4psi, 12psi, 20psi, 28psi, 36psi, 44psi, etc. It does work, I have tried it before. Just enabled the software with the 3bar option, and remember that the boost column labeling doesnt pertain anymore. Remember its just a 0-5v signal. The 5bar is doing the same thing as the 3bar, just shrinking the resolution in boost.
Old Jul 14, 2004 | 09:45 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: HONDATA + 5BAR MAP? (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">Hondata can run the 5bar map sensor. All the vacuum columns remain the same as with the 3bar option enabled, but the boost columns are not what they are labeled in the software. The boost columns are spread out further apart i.e it doesnt go 4psi, 8psi, 12psi, 18psi, 24psi, 28psi...its more like 4psi, 12psi, 20psi, 28psi, 36psi, 44psi, etc. It does work, I have tried it before. Just enabled the software with the 3bar option, and remember that the boost column labeling doesnt pertain anymore. Remember its just a 0-5v signal. The 5bar is doing the same thing as the 3bar, just shrinking the resolution in boost.</TD></TR></TABLE>
You are the 2nd person I know that has done the 5-bar map sensor. It works!! You just have to know how to convert it. All hondata would have to do is change the software, I would think at least.
art
Old Jan 21, 2005 | 08:29 AM
Spunkster's Avatar
There is now beta software available from Hondata that supports 5-bar.
cachehx
Feb 6, 2008 10:19 AM
BigMoneyP
Sep 9, 2005 02:22 PM
BoOsTiN Dc2
Apr 1, 2004 11:17 AM
R THIS
Dec 14, 2002 03:39 PM
