epoxy primer
Old Dec 8, 2011 | 11:59 AM
jdmcx's Avatar
Default epoxy primer
anybody have any experience with a certain brand of epoxy primer under polly primer?
was planning on using the PPG epoxy but was told that i could run into problems if i didn't use an etching primer before the epoxy
what epoxy primers do you use?? (i plan on using featherfill g2 over it )
Old Dec 8, 2011 | 02:14 PM
joeshmo's Avatar
Default Re: epoxy primer
You aren't supposed to put epoxy over etch. At least, I've always been told that is a big no no. Epoxy primer forms a mechanical bond directly to the substrate and does not require an etch primer.
I have used kirker epoxy primer and I love the stuff. Unlike other epoxies, it sands very easy and is rather cheap.
I have also heard great things about SPI (southern polyurethane) epoxy primer. They'll answer any questions you have about their products via email or phone and their p-sheets are great.
Featherfill will be fine to go over epoxy.
Old Dec 8, 2011 | 02:18 PM
gorillafart's Avatar
who told you that you would run into problems if u didnt put self etching first? they were an idiot
u can use self etching, be4 i use a regular primer surfacer....
or u can find a sandable epoxy primer that is like a surfacer, with the epoxy protection
Old Dec 9, 2011 | 04:16 AM
jdmcx's Avatar
what i was told was that if I plan on using PPG epoxy primer i would have to use an etching primer first then spray ppg epoxy i dnot know will probably give spi a call i was just trying to stay within the same brand to make sure everything is compatible
Ziprock
Paint and Body
Feb 24, 2010 03:54 AM
will7
Jan 10, 2006 07:54 PM
WildS2K
Honda S2000
22
Jan 10, 2006 10:12 AM
Lost Type R
Oct 10, 2002 11:19 AM
00b18b
Oct 5, 2001 05:13 PM
