stock type r valves weak?
Old Oct 24, 2005 | 05:40 AM
no mods's Avatar
Default stock type r valves weak?
about to purchase a NEW cylinder head with type r valves. unfortunatly i have been informed that the stock type R valves are weaker and Often brake. Is this common or has anyone ever run into problems running them with springs and retainers on a high boost application? the motor will only ever see <9k rpms... now i know i should throw some ss turds in there but the head is new and dont feel like spending additional 300 dollars on somethign that i may not have too.
Old Oct 24, 2005 | 05:54 AM
PM-Performance's Avatar
Default Re: stock type r valves weak? (no mods)
you heard wrong
Old Oct 24, 2005 | 06:28 AM
drumking15's Avatar
ive been running mine for the past season...wokring fine for me up to 8k w/ dual valve springs for increased seat pressure
Old Oct 24, 2005 | 07:07 AM
g2turbo's Avatar
Default Re: (drumking15)
I also think that you will be just fine.
Old Oct 24, 2005 | 07:12 AM
TheShodan's Avatar
Moderator
Default Re: (g2turbo)
I believe you were rather misinformed..
Old Oct 24, 2005 | 09:25 AM
Default Re: (TheShodan)
Matter of fact i rarely shifted under 9200 rpms. . . Stock ITR head.
Old Oct 24, 2005 | 10:23 AM
CivicBwoy's Avatar
that is BS
Old Oct 24, 2005 | 10:56 AM
RACEPAK's Avatar
Default Re: (CivicBwoy)
what about the b16b2 valves?
Old Oct 24, 2005 | 03:37 PM
teri_vti's Avatar
so finally, which valves would you recommend as the most safe-appropriate for a b18 GSR turbo kit (lets say for around 350-400whp)??
what retainers also and what springs??
would typer r double springs and typer valves be ok?? ( i am talking using them with GSR cams)
Old Oct 24, 2005 | 03:58 PM
Flr Power's Avatar
Default Re: (teri_vti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teri_vti &raquo;</TD></TR><TR><TD CLASS="quote">so finally, which valves would you recommend as the most safe-appropriate for a b18 GSR turbo kit (lets say for around 350-400whp)??
would typer r double springs and typer valves be ok?? ( i am talking using them with GSR cams)</TD></TR></TABLE>
Power has nothing to do with it. Think about RPM's.
Old Oct 24, 2005 | 04:01 PM
drumking15's Avatar
Default Re: (Flr Power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flr Power &raquo;</TD></TR><TR><TD CLASS="quote">Power has nothing to do with it. Think about RPM's.</TD></TR></TABLE>
ya but seat pressure still has to be strong enough to not open during hi boost~
Old Oct 24, 2005 | 06:22 PM
DontBlink's Avatar
i use all my stock type r parts in the head. no issues for the last 3 years. shifting at 8500.
Old Oct 24, 2005 | 09:14 PM
no mods's Avatar
Default Re: (DontBlink)
thanks for all the replies .. I do believe my concern is valid because the type r valves are infact smaller in diameter (at some point on the valve) on the one side of the head. I too already have dual springs that will be adding to the seat pressure. I know Honda typically would not compromise the integrity of a part to save a few oz.'s but im sure honda did not factor in the additional stress caused by an aftermarket Heavy duty spring and added pressure levels of a turbo/potential problems caused by it. No one wants to burn a built motor because they saved 300 dollars by not getting a set of valves. I know what I should do ideally . but also curious if running these stockers are a feasible option
a few people say that they have not experienced any problems .. have you heard of people who have?
Modified by no mods at 6:28 AM 10/25/2005
Old Oct 27, 2005 | 07:43 AM
teri_vti's Avatar
i think i ll be rev around 8800....
so is it safe to use typer valves and dual springs ?
the pressure wont exceed 15psi
i want something safe and reliable...i dont care paying something more now if this means i wont blow the head
98integralsB18
Apr 19, 2012 10:36 AM
GReddy SI
Oct 31, 2009 07:19 PM
fms1day
13
Jul 12, 2006 05:29 AM
tcb18c5crx
May 18, 2003 06:20 PM
