do ineed fuel pump ?
Old Mar 24, 2004 | 08:19 PM
blackccoupe's Avatar
Default do ineed fuel pump ?
hey guys got my 14b turbo setup on today i have an fmu and a fpr do i need a fuel pump and will a 255 be ok if i do let me know
Old Mar 27, 2004 | 09:14 AM
Default Re: do ineed fuel pump ? (blackccoupe)
Old Mar 29, 2004 | 05:43 PM
hondawill's Avatar
u need to get a fuel pump. i got a walbro 255. you need to have plenty of fuel when running a turbo. u don't want your car to lean out.
Old Mar 29, 2004 | 06:31 PM
iiilgsrlll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackccoupe &raquo;</TD></TR><TR><TD CLASS="quote">hey guys got my 14b turbo setup on today i have an fmu and a fpr do i need a fuel pump and will a 255 be ok if i do let me know</TD></TR></TABLE>
You will need an inline NOT intank if you're deciding to run an 12:1 Vortech FMU. The intank will not supply enough fuel.
Old Mar 30, 2004 | 05:07 AM
Default Re: do ineed fuel pump ? (iiilgsrlll)
dam i got a intank already anyway i can just replace the disk for a smaller ratio or do i need that ratio disk
Old Mar 30, 2004 | 04:19 PM
Old Mar 30, 2004 | 04:24 PM
Clutch101's Avatar
Changing your disk in your FMU will depend on your A/F curve printout. You can install a inline pump with the intank pump too. I run a 255 intank with a accel inline.
Old Mar 30, 2004 | 04:33 PM
Flr Power's Avatar
Stock fuel pump good for at least 200 whp!
Old Mar 30, 2004 | 04:48 PM
TeamCracka's Avatar
Default Re: do ineed fuel pump ? (coocoo32)
I've got a Walbro 255 intank and 450's
I'm also using the B&M FPR and since it uses the stock bottom end of the FPR, it cant flow enough fuel back to the pump causing a SUPER rich idle.
If you also have a B&M, as you prolly know you can drill a hole of about 0.030" to allow it to return more, but then you run the possibility of running lean from TOO much fuel returning...
Anyway, my point is if you do get an intank pump, plan on buying a new FPR, and not the $30 "adjustable" one B&M makes.
Old Mar 30, 2004 | 04:54 PM
iiilgsrlll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coocoo32 &raquo;</TD></TR><TR><TD CLASS="quote">Stock fuel pump good for at least 200 whp!</TD></TR></TABLE>
Ok...go ahead and run the stock fuel pump and 12:1 FMU and tell me what happens as soon as you hit boost.
Old Mar 30, 2004 | 06:05 PM
lol
so should be ok with the intank? putting it in tom. also any info on plugs?
Old Mar 30, 2004 | 06:06 PM
also should i use the b n m or no or shoudl i get a better fpr
Old Mar 30, 2004 | 06:14 PM
danl's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iiilgsrlll &raquo;</TD></TR><TR><TD CLASS="quote">
Ok...go ahead and run the stock fuel pump and 12:1 FMU and tell me what happens as soon as you hit boost. </TD></TR></TABLE>
Exactly
Fuel pumps aren't limited by HP. They are limited in flow. Flow is affected by the pressure the pump is pushing.
Old Mar 31, 2004 | 08:09 PM
Default Re: do ineed fuel pump ? (danl)
k put the fuel pump in all i got to say in dam! lol
Old Mar 31, 2004 | 10:25 PM
Charles B.'s Avatar
how is it running?
Old Apr 1, 2004 | 04:36 AM
Default Re: do ineed fuel pump ? (SuperDuperEG)
didn't think the pump would make that much of a diff. it is night and day lol
Old Apr 1, 2004 | 08:09 AM
Bontke's Avatar
What the hell would you install an up graded inline and upgraded intank? Maybe it is a miss print, but you should only need one or the other upgraded. I suggest intank pump incase the stock pump fails or cannot keep up with an inline. And if that isn't good enough, then add a larger fuel line and use the stock sending line and the return line.
KrispyKreme
Apr 20, 2005 03:52 PM
civproject14
Dec 19, 2004 10:07 PM
civicdragger818
Jun 20, 2003 01:07 PM
KevronsEG
Jul 21, 2002 01:43 PM
b18tdelsol
May 19, 2002 07:09 PM
