H23
Old Feb 9, 2007 | 08:21 AM
Neonxiii's Avatar
Default H23
Ive searched alot, there isnt a whole lot of info on boosted H23's as there is for H22's. Anyhow i have a list of all the turbo accessories and such for my motor. I am not sure if this is the right section for this but How much psi can i run in a stock block?
About a month after i boost, i am purchasing Crower Stage 2 Cams for boosting, some springs/retainers.. Cam gears and Pulleys. I know that isn't really internal work but its a start.
I also read on forums that you can run 10/15psi on the H23 stock block? i find that hard to believe. My goal is for a 250WHP daily driver.
Old Feb 9, 2007 | 09:02 AM
carnot's Avatar
Default Re: H23 (Neonxiii)
If you are only shooting for 250whp I wouldn't worry about the cams and head work you were considering; put your money towards solid internals and the turbo accessories. As far as how much boost a stock bottom end can handel really depends on the condition of your bottom end. Get a leak down and compression test done and these numbers will help you decide on the state of your combustion chambers.
Old Feb 9, 2007 | 09:08 AM
Neonxiii's Avatar
Default Re: H23 (carnot)
Solid Internals?
Well why not get Shafts? i will fee; a bit safer with them. My goal is 250whp but i may want to got 275/300.
Old Feb 9, 2007 | 09:20 AM
carnot's Avatar
Even up to 300whp stock drive shafts should hold up unless you are going to be running slicks and really launching hard. In the 250-300whp range a big concern becomes uneven wheel spin so an investment in an LSD might be worth your consideration.
Old Feb 9, 2007 | 10:44 AM
esedulerp5tenin's Avatar
i'm hoping for around 230hp'ish on my h23 with a t3/to4e @ 7psi. so far she's daily driven, and hopefully will keep it that way. i wouldn't go over 8psi on a DD stock block.
like carnot said, dont even worry about camshafts and headwork, but that money in the bottom end if you can
*edit* and hopefully my sh*t will be in next week. will keep you updated
Old Feb 9, 2007 | 10:58 AM
carnot's Avatar
Default Re: H23 (esedulerp5tenin)
what are the full specs on your setup?
Old Feb 9, 2007 | 03:13 PM
Neonxiii's Avatar
my setup?
Old Feb 9, 2007 | 03:16 PM
genocide43110's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neonxiii &raquo;</TD></TR><TR><TD CLASS="quote">my setup?</TD></TR></TABLE>
I think he means esedulerp5tenin's setup
Old Feb 9, 2007 | 03:20 PM
H23 stock internals with:
t3/to4e 57 trim
tial 38mm w/g
hks ssqv
6" JDMsport IC
5th gen IC piping
hermsfab logstyle manifold
walbro 255
DSM 450's
stealthmode oil lines
andddddd chipped p06 with crome
Old Feb 9, 2007 | 04:52 PM
Neonxiii's Avatar
aight, with that how much psi are you running?
how is it during WOT?
tron-R
Feb 25, 2008 04:19 AM
thegeorge613
Nov 6, 2005 09:05 PM
Silude95
Sep 18, 2004 01:48 PM
Regulator
Jan 9, 2003 09:39 AM
flip1199
May 5, 2002 03:07 PM
