h22 turbo setup
Old Feb 13, 2006 | 09:30 PM
boosted2point2ek's Avatar
Default h22 turbo setup
this is the setup im going with on my jdm h22a in my 99 hatch, i plan on running a tuned 7psi but was wanting to get opinions on how well this setup would do with 10psi
Darton Sleeves
eagle h-beam rods
je pistons w/ 9:1 compression
rc 650 injectors
walbro 255 fuel pump
hondata s300
precision sc34 turbo
2.25 hot side piping
2.5 cold side piping
revhard intercooler
turbosmart 35mm wastegate
greddy type rs bov
3" exhaust
arp head studs
oem oil and water pump
oem honda bearings
h23 tranny
spec stage 3+ clutch
obx manifold
thanks in advance
Modified by h22a ek9 at 11:34 AM 3/2/2006
Old Feb 14, 2006 | 05:20 AM
Default Re: h22 turbo setup (h22a ek9)
anyone?
Old Feb 14, 2006 | 05:22 AM
The Weather Man's Avatar
.......great start
Here's why:
eagle h-beam rods
je pistons- oversize bore .10 w/ 9:1 compression
dsm 550 injectors I'd personally go with RC/precision injectors - but i guess
hondata s300 GREAT choice!!!!
phantom grip valvetrain set never heard of them - hopefully they're good
crower stage 2 turbo cams get cam gears with them
precision sc34 turbo could chose something better especially since you're building the bottom end
revhard intercooler
turbosmart 32mm wastegate Too small
greddy type rs bov
3" exhaust
aebs or arp head studs
oem honda bearings
h23 tranny why??
obx manifold hahaha
thanks in advance
Old Feb 14, 2006 | 07:04 AM
pentaq's Avatar
Default Re: (TheKINGPin)
you nowhere mentioned the engine will be sleeved... It's a must with JE pistons...
Old Feb 14, 2006 | 07:10 AM
Default Re: (pentaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">you nowhere mentioned the engine will be sleeved... It's a must with JE pistons...</TD></TR></TABLE>
Yeah i noticed that also - but i'm assuming he already knew that.
Old Feb 14, 2006 | 07:13 AM
are there any pistons that i can use without resleeving the block? im not looking to go that far with the block
thanks for the help and opinions
Old Feb 14, 2006 | 07:30 AM
crazykid's Avatar
mahle pistons.
Old Feb 14, 2006 | 07:34 AM
Default Re: (crazykid)
yea thanks, they have a set that is bored .25 over that i might just have to go with instead of the je
http://www.importperformancepa....html
Old Feb 14, 2006 | 07:39 AM
Be careful with that website - they 'lose' a lot of orders, including one of mine - and another guys. Make sure you talk to them before hand because they don't add shipping costs when you order (which is stupid). But i'm going with the goldseries pistons myself. Good luck man.
Old Feb 14, 2006 | 07:43 AM
i just did a search and used that for a reference, i order all my parts through a local shop at "cost" and will just tell them to respecify which pistons, i think he thought i planned on resleeving the block. it would be nice but i just want to build a nice 7-10 psi daily driver!
should that setup be adequate for an occasional 10 psi?
also what is everyone's opinions on head studs? aebs or arp
Old Feb 14, 2006 | 07:52 AM
man that setup is great for 10psi - you could run more if you wanted.
The only thing weak about the H series engines are the stock pistons. The crank comes forged from factory. So, just change the pistons and rods and you should be good to go. I was thinking about doing just 10psi on my setup, but i'm going with a little smaller turbo - so i might have to do ~12 or so.
I have the ARP headstuds. Got 'em for cheap.
Are you getting a discount on the pistons from the dealer?
Old Feb 14, 2006 | 08:12 AM
if im not mistaken i can get the je's at dealer cost, but im not sure if i can get the mahle's
Old Feb 14, 2006 | 08:29 AM
gt25CIVICex's Avatar
Default Re: (h22a ek9)
you will stil need to do a slight (and i mean SLIGHT) overbore even with the mahles. check out the new issue of Honda Tuning theres a tech article about upgrading the H22 rotating assembly without having to use aftermarket sleaves
Old Feb 14, 2006 | 08:38 AM
Default Re: (gt25CIVICex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gt25CIVICex &raquo;</TD></TR><TR><TD CLASS="quote">you will stil need to do a slight (and i mean SLIGHT) overbore even with the mahles. check out the new issue of Honda Tuning theres a tech article about upgrading the H22 rotating assembly without having to use aftermarket sleaves </TD></TR></TABLE>
http://hondatuningmagazine.com/tech/0501ht_h22tech/
this what your talking about?
Old Feb 14, 2006 | 08:44 AM
https://honda-tech.com/zerothread?id=627472
i see what you are talking about, there is a debate about not being able to re-hone the h22 cylinder walls, so now im just debating on wether or not to go with the .25 overbore...but with the mahle i can run the stock bore and that will keep me from hopefully having to rehone
Old Feb 14, 2006 | 09:03 AM
ok...so we called je and they said due to the frm cylinder you can not bore the sleeve, thats why they reccomend using aftermarket sleeves...BUT they have recently developed a piston ring that will work with the frm sleeves!! but it takes about 2 weeks to make it after ordering it through je...so you can either use the mahle with the rings they developed or je has options for anyone who wants to run the stock sleeves with the aftermarket pistons!
Old Feb 14, 2006 | 09:10 AM
boosted94cx's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22a ek9 &raquo;</TD></TR><TR><TD CLASS="quote">eagle h-beam rods
je pistons- oversize bore .10 w/ 9:1 compression...sleeves.. either go with the mahle gold lines now, or wait a little and get teh weisco drop ins when/if they come out..that's what i'm doin
dsm 550 injectors just get some 1000cc injectors and be done with them
walbro 255 fuel pumpmake sure you get the HP
hondata s300WASTE OF MONEY...go with crome, it's cheaper and just as powerful and just as user friendly
phantom grip valvetrain setditch that and get RM stuff...they're proven
crower stage 2 turbo camsWASTE of money, stock cams will make more power for you, i assure you
precision sc34 turbo too small...serioulsy, bump it up to at least a .82a/r 60-1...you'll still see good spool..but you'll have less back pressure to deal with and more turbo
revhard intercoolergo ebay, they're larger and just as good of a core..but cheaper
turbosmart 32mm wastegatemight wanna take one step up from that...to at least a 38mm gate from tial...or possibly wait for the new 41mm gate to be released
greddy type rs bov
3" exhaust
oem honda bearings OE honda bearings suck in performance situations...i'd advise going another route..king possibly
h23 tranny while you SHOULD be using a B-series tranny..haha, i'd advise going with a JDM LSD h22 tranny...
obx manifoldintake or exhaust? we've got an intake on the way to test with
thanks in advance</TD></TR></TABLE>
Old Feb 14, 2006 | 09:23 AM
thats not the article im refering to, i just got the issue in the mail so im not sure if its on store shelves yet. but basicaly it revolves arount the fact that you cant overbore H22 cylinders at least by normal standards. but you can do a .25 overbore (which is miniscule) but enough to clean up the bores for the mahle pistons. if i can find the article online ill post a link.
Old Feb 14, 2006 | 10:39 AM
Heres a link to the contents of the new issue of honda tech:
http://hondatuningmagazine.com/toc/thismonth/
the article i was talking about is "Bored to be Wild"
kornkid21792
Sep 29, 2009 04:02 PM
#1rudebwoy
Jun 29, 2009 05:26 PM
JDM.Accord
Feb 15, 2005 08:32 AM
