h22a1 turbo set up
h22a1 turbo set up
I have a h22a1 and im dropping it into a 2000 prelude shell and i have my hp goal around 445 - 455 so is that possible and using a gt32 turbo?
Re: h22a1 turbo set up
well the tuner is a good guy and knows a lot i have 1000 injectors and walbro fuel pump hp, spoolin preformance log manifold
I made 465whp @18 psi on a GT30 (built H22). Had 750 injectors, Walbro, GE intake, Hondata S300 before I switched to E85, GT35, 1600s etc. Assume you're H22 isn't stock internals?
no not at all mahley pistons and eagle rods but i didn't know it could handle all of that fuel (1600) if a gt32 is a good turbo then i will use it.
im building a h22 on boost i have 450cc injectors will they work on my turbo setup the motor is built. also i dont know what i should run my car on hondata crome etc
jdmGSR.fo0!
03-02-2005 12:58 PM
