!!h22 Goldeneagle scattershield pictures or install help!!
Does anyone know where i can find pictures of an h series GE scattershield? for some reason its not fitting right on my h22. its hitting my clutch slave cylinder. and not sure where the bottom part of the shield should bolt up to (i know its one of the case bolts but dont know which one).
Thanks in advance
Thanks in advance
Re: !!h22 Goldeneagle scattershield pictures or install help!! (ki11a8ee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ki11a8ee »</TD></TR><TR><TD CLASS="quote">Does anyone know where i can find pictures of an h series GE scattershield? for some reason its not fitting right on my h22. its hitting my clutch slave cylinder. and not sure where the bottom part of the shield should bolt up to (i know its one of the case bolts but dont know which one).
Thanks in advance </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1815499
Re: !!h22 Goldeneagle scattershield pictures or install help!! (DfwBB6)
i think that picture is for a b series motor if not then i have the wrong one cause the bottom bracket is different from the one i have can someone tell me if that picture of the scattershield is for a b series or h series motor
thats actually not an h series bracket i did a google search and found a picture of an h series scattershield. ive got the right one. the only difference is the bottom bracket that connnects to the bottom of the bolt is different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ki11a8ee »</TD></TR><TR><TD CLASS="quote">thats actually not an h series bracket i did a google search and found a picture of an h series scattershield. ive got the right one. the only difference is the bottom bracket that connnects to the bottom of the bolt is different.</TD></TR></TABLE>
ah your right the h series lower bracket is alot bigger. sorry must have been late.
clutch, eagle, golden, goldeneagle, h22, honda, install, installation, integra, picture, pictures, replacement, scatter, scattershield, series, shield
