Clutch lines for h22 swap?
When you guys did an h22 swap in a civic how did you hook up the clutch lines to the h22 tranni since it's different from a d series tranni, did you guys just reflare all the lines? thanks for the help, pics are alos nice
Re: Clutch lines for h22 swap? (2trix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2trix »</TD></TR><TR><TD CLASS="quote">i actually just used my whole slave and line ***.! just needed to make and plate to bolt it up but everything works great!</TD></TR></TABLE>
Yup, you need to use the Prelude/Accord slave cylinder if you want it to bolt right up to the tranny. You can still use your Civic slave cylinder but you need to drill out one of the mounting holes about 1/4" for it to bolt onto a the H/F-series transmission.
Re: Clutch lines for h22 swap? (jdmcivicferio)
i used the sohc slave. i had to modify it a little to fit...but it works nicely, also if you use the sigle cam clutch hose it'll make your life alot easier..
ki11a8ee
04-14-2007 07:01 AM
UpstateCivic
04-27-2003 12:15 PM
