h-t afc hack info
Old Jun 10, 2006 | 01:53 PM
  #576
zerovandez's Avatar
Still alive!!
Old Jun 10, 2006 | 05:58 PM
  #577
thermal's Avatar
Dannnnng..... this thread is still alive?
.... I dont recommend using this anymore since there are at least 2-3 free systems out there now. If there is any consolation, I ran the AFC hack for 3 years on my stock D16Y8 turbo at 10 psi. Never had an issue. The motor blew but not because of the hack. The oil pan cracked and was leaking oil.... so it ran dry for a few days. Didnt realize it cuz there was so much snow and ice on the ground.
Old Jun 10, 2006 | 07:06 PM
  #578
93CX's Avatar
Default Re: (thermal)
I keep reading people talking about how uberdata and crome are "free". This isnt the case for me, as the nearest dyno tuning place that could tune on either of those platforms is over two hours away from me. It would also cost money for me to have my ecu socketed to read uberdata. I will be running the AFC hack on my B16T setup with Walboro 255, stock fpr, dsm 450s, and a vafc until I have the ability to get it tuned
Old Jun 10, 2006 | 11:21 PM
  #579
AbitAvenger's Avatar
Default Re: (93CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX &raquo;</TD></TR><TR><TD CLASS="quote">I keep reading people talking about how uberdata and crome are "free". This isnt the case for me, as the nearest dyno tuning place that could tune on either of those platforms is over two hours away from me. It would also cost money for me to have my ecu socketed to read uberdata. I will be running the AFC hack on my B16T setup with Walboro 255, stock fpr, dsm 450s, and a vafc until I have the ability to get it tuned </TD></TR></TABLE>
Maine
Adam Clayman
-F1 Dyno
-1039 Riverside St
-Suite 10
-Portland, Maine 04103
-http://www.f1dyno.com
-email- http://adamc@fidyno.com or info@f1dyno.com
-H-T name- Bailhatch
-Phone 207 347-8078
-AWD Chassis Dyno tuning; Uberdata, AFC and many non-honda managments such as UTEC, VEC2, DSM link, LS1 edit etc.
D and B series engine building, swaps, fabrication, manifolds, exhaust work, parts install.
He near you at all or is that who you are saying is 2+ hours away? I bet you could chip your own ecu and have someone street tune it no problem
Old Jun 11, 2006 | 08:05 AM
  #580
93CX's Avatar
Default Re: (AbitAvenger)
yup, F1
its more than two hours away
plus, I dont want to spend lots of cash on a tune when I need new internals anyway, running CTR pistons because it was originally a NA application. Only shooting for 5psi for right now.
Old Jun 11, 2006 | 10:27 AM
  #581
Dueceification's Avatar
Default Re: h-t afc hack info (liam821)
i personaly dont run VAFCs and recomend to most of my customers to removed and sell them. For the money you spent on all these things you could've just bought a chipped out p28 and some injectors and would've been good Any place that can program hondata should beable to program a crome / uberdata setup with out any problems as they are similar. A tuned p28 will be much more reliable then a VAFC. But hey what ever works
Old Aug 20, 2006 | 08:43 AM
  #582
oneoffaccord's Avatar
Default Re: h-t afc hack info (93b16hatch)
i guess im bringing this back from the dead as well. im running a h23 turbo in my accord. i too have the afc. my car runs rich as hell at idle 9.5-10.4 on the wideband. runs strong until 3k-4k thats when i feel a hestiation and stumpling. then after that the check engine light comes on. then from 4k and up it pulls hard as hell. 15.7 a/f the most. then the manifold get red hot. im going to changing to the DSM injectors cuz i have a set at home. this is the greatest.
I WILL TRY Laim set up and see what happens
93 USDM H23
RC 310CC INJECTORS
SPEARCO INTERCOOLER
TURBONETICS DELTAGATE WASTEGATE
TURBONETICS T3/T04E TURBO
TURBO XS MANUAL BOOST CONTROLLER
APEXI S-AFC
MSD 6BTM
B&M FUEL PRESSURE REGULATOR
WALBRO 255LPH FUEL PUMP
ANY COMMENTS HELP POST THEM
Old Aug 20, 2006 | 12:39 PM
  #583
-RedneckDave-'s Avatar
Working
Default Re: h-t afc hack info (oneoffaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneoffaccord &raquo;</TD></TR><TR><TD CLASS="quote">i then from 4k and up it pulls hard as hell. 15.7 a/f the most. then the manifold get red hot
Old Aug 20, 2006 | 01:39 PM
  #584
93CX's Avatar
Default Re: h-t afc hack info (-RedneckDave-)
lol. ^^
anyone know if i need a resistor box for obd1 dsm 450s if i'm just using vafc? i cant seem to find a definate answer
Old Aug 20, 2006 | 08:07 PM
  #585
Default Re: h-t afc hack info (93CX)
yes you need a resistor box for the DSM injectors^^^^
well i changed my settings like Laim had his but a lil less. I ran 100% better but its throwing a CEL. most it wil run is 14.7 ish at WOT. then im leaving my girls house and it wont take off. so i ended up putting -16% at low and high throttle. before i had the throttle setting at 98% low and 99% high. then switched to 40% and 50% off i went. but still throws a cel. only boosting 5lbs for now. still using the 310cc?
Old Aug 23, 2006 | 02:54 PM
  #586
what the pressure sensor set at on your guys afc? i got mine at IN-2 OUT 2
Old Aug 23, 2006 | 03:29 PM
  #587
y7turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneoffaccord &raquo;</TD></TR><TR><TD CLASS="quote">what the pressure sensor set at on your guys afc? i got mine at IN-2 OUT 2</TD></TR></TABLE>
dude you need dsm 450 or any aftermarket 440cc injectors to run the hack. thats why your getting a check engine light. you dont have the afc scaled back far enough to pull the map voltage down.
6in 6 out
wow
Old Aug 23, 2006 | 04:19 PM
  #588
RACEPAK's Avatar
Default Re: h-t afc hack info (y7turbo)
ok...so...
my car idles ok when i set it to 06 06 but it drive like crap.... especialy in cruise .
but when i set it to 05 06 the idle is crappy but the car drives like hell...(that means OK)
i tryed 2 map sensors and i got nothing.....
what can i do?
ps.
turbo'd
with 450's
Old Aug 23, 2006 | 07:09 PM
  #589
Default Re: h-t afc hack info (RACEPAK)
thanks for the info. i was goingto install the 450s tonite but i had to make the injector spacers bigger. i only had 1 need to find 3 more and ill be good.
Old Aug 24, 2006 | 03:35 PM
  #590
y7turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">ok...so...
what can i do?
ps.
turbo'd
with 450's
what is the a/f ratio when it runs like ****? its not going to automatically tune itself when you do 6in6out.
what are your fuel settings?
Old Aug 31, 2006 | 05:12 PM
  #591
installed the 450cc in. set it up like Laim did wonderful. still getting a CEL at 8lbs still need to play with the settings and see what happens
Old Sep 4, 2006 | 04:17 PM
  #592
car runs wonderful. hit 221.8hp @5250 and 237.4ft-lbs@4600 running 7 or 8 lbs. running rich as hell 9.9-10.8 on the wideband o2.
Old Feb 10, 2007 | 11:51 AM
  #593
h22sedan's Avatar
Ok, I'm considering using this for my setup as a temp fix until I can afford Hondata. I'll be running...
T3/To4E .57 trim .63 A/R
Peakboost Version 1 manifold
DSM 450's
Walbro 255LPH Hi-pressure fuel pump
Aeromotive FPR
Apex'i V-AFC
TiAL BOV and External Wastegate
Turbo XS boost controller set to 8psi
FMIC'd
AEM UEGO wideband, Autometer Boost and Oil PSI gauges
...also considering buying MSD Boost Master Ignition box. ???
The kit isn't installed yet, will be going on an H22.
Will this work for me?
From my understanding all I have to do is set the fuel trims as Liam says in the first post, run the MAP unlimited, set the fuel pressure to 40psi. I'm just using this as a temporary fix until I can get S300 here in a month or so. I don't expect to make gobs of power but after Hondata I plan for around 300whp or so.
Old Feb 11, 2007 | 05:53 PM
  #594
h22sedan's Avatar
Default Re: h-t afc hack info (h22sedan)
BUMP. Anyone experienced?
Old Feb 11, 2007 | 06:47 PM
  #595
nonvtecD's Avatar
Lots of free engine management out there, the AFC hack should be dead.
Old Feb 14, 2007 | 09:29 AM
  #596
Kutsuju_SLeePER's Avatar
WOW...i didnt think people still ran this set-up..I did the AFC hack about 2 years ago...It did its job though i have to say. But i agree, loads of free EM out there. Just gotta learn to mess with the programs and a wideband if no dyno
craio
Aug 22, 2005 08:53 AM
i3oricua
Mar 4, 2003 10:18 AM
HondaCutter
Mar 2, 2003 03:41 PM
Hybrid
Sep 13, 2002 05:56 AM
Jockobo
Jun 25, 2002 09:19 AM
