Gtech on a turbo d16z6....help with results.
Hey guys, some of you might think its that accurate but i have seen it come within .1 sec alot at the track in my buddies car. Anyways I ran acouple runs on the turbo d16z6 today. I was hitting 7psi until around 6Krpm where it starts to drop down to 5.5-6psi. Anyways here are the results, please state what if any number seem off to you guys. GTECH dyno graph at bottom.
60ft----2.345
1/8th--9.709 @77.34mph
1/4----14.825 @ 96.78mph
60 ft----2.323
1/8th--9.670 @ 76.90mph
1/4----14.864 @ 94.68mph
60ft ----2.329
1/8th-- 9.624 @ 77.59mph
1/4 ----14.756 @ 96.40mph
Quick breakdown of the car....
95 coupe with d16z6
greddy kit @ 7psi drops to 6psi of so after 6K
drag fmic
AFC hack
2.5in exhuast, highflow cat to magnaflow
bully clutch / 9lb flywheel
Falken azenis set at 38psi on 14in wheels
Dont mind the info in the top left corner as you dont launch and only run 1 gear about 3K rpm. This graph was done in 3rd gear. Notice the power level out around 6K when boost starts to drop. Also what HP increase do you guys think should be there if i get to hold 7psi to redline?
If anymore info is needed, post up and i will respond.
Thanks
60ft----2.345
60 ft----2.323
60ft ----2.329
95 coupe with d16z6
drag fmic
AFC hack
Thanks
Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">which gtech did you use?
i saw this on ebay for cheap
http://cgi.ebay.com/ebaymotors...46100</TD></TR></TABLE>
I used the one of the older models the Gtech Pro Competition. I was alittle disappointed to see the psi drop off near redline. I will be pressure testing the piping in the next few days. I just hope the older TD04H-15C doesnt just die out on me in top end.
Also iam using a profec B 1st model, i have the balance set of full and run off only the low boost setting for now. Should i try and run 7psi on highboost, or will it make no difference? Also would the balance **** maybe help?
racinskittle
10-28-2003 06:07 PM
