hahn 16g on d16z6
Old Jan 24, 2007 | 07:26 PM
jarvis199's Avatar
Default hahn 16g on d16z6
Hey guys ive got a hatch with a built block (vitara/eagle) and i had a turbonetics 60-1 on it and really didnt like the powerband so i decided to switch.
I swapped it to a buddy for his hahn 16g (t3 flanged) its got the 10cm exhaust housing, and in excellent shape, ive street tuned it to 20 psi, and it honestly feels like it pulls harder than the 60-1 did.
The 60-1 setup dynoed at 280whp and 210wtq on a dyno dynamics, which seemed very low to me at 21 psi...
My question is, what do u guys think this turbo is capable of hp wise??? My head is 100% stock other htan the arp headstuds... Thanks for any input...
oh and Hahn claims this turbo to flow 45 lbs...
Old Jan 24, 2007 | 07:31 PM
turbociviccoupe's Avatar
Default Re: hahn 16g on d16z6 (jarvis199)
that is really low for 21 psi. dyno then let us know
Old Jan 25, 2007 | 07:41 AM
jarvis199's Avatar
Default Re: hahn 16g on d16z6 (turbociviccoupe)
well i was told that dd dynos read REALLY low to start with, and that my dynojet number would be more aroudn 320-330...
im planning on dynoing thecar again really soon, just curious whether or not this turbo will make 400whp???
Old Jan 25, 2007 | 07:50 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jarvis199 &raquo;</TD></TR><TR><TD CLASS="quote">well i was told that dd dynos read REALLY low to start with, and that my dynojet number would be more aroudn 320-330...
im planning on dynoing thecar again really soon, just curious whether or not this turbo will make 400whp??? </TD></TR></TABLE>
I don't think the Hahn 16g will make 400whp. The evo3 Big 16g will get you there closer and spool quicker, but remember that DSMs are 2.0L, and have boost friendly CR's (7.8-8.5 CR).
The 10cm^2 exhaust housing on the Hahn turbos make for more lag, but on the other hand, is capable of higher rpms w/o choking. The difference you feel from this smaller turbo compared to your 60-1 is the increased powerband (more area under the curve, instead of higher peak numbers).
Got a graph of the 60-1 dyno numbers? I'm curious as to when it started spooling. 280whp @ 21psi means that there might be something wrong with your setup. Figure that out first and work from there.
Old Jan 25, 2007 | 02:54 PM
jarvis199's Avatar
Default Re: hahn 16g on d16z6 (Finest)
well a 60-1 on a stock head/intakemanifold z6 seems to be a problem from what ive heard, heard that from geoff at full-race and several o theres, that 60-1+d16 dont mix well for some reason???
this turbo is supposed to be BIGGER than an evo3 16g by a little, supposedly compared to a evo 8 16g in flow numbers...
and it for sure DOESNT choke out up top, flows excellent...
timing was fairly conservative since this was on pump gas, pretty sure total timing was at 5*@21 psi (i tuned it but kind of been a while so i forgot what timing was at)
the car made only 210 tq with that turbo, which i also thought might have been an issue, i do enjoy the larger powerband tho... i called hahn and the man i spoke with told me on a 2.0 liter they typically see 350whp@ 25psi out of this turbo, which seems decent to me...
Old Jan 25, 2007 | 03:21 PM
93turbo16's Avatar
I had the same turbo on my old vitara build, the hahn super 16g exhaust housing, with a big 16g compressor side. It was making around 250 on 14 psi. On a relatively (lower) reading dyno. So the turbo is defintitley capable. But not sure about 400 whp with that compressor side.
Old Jan 25, 2007 | 03:29 PM
jarvis199's Avatar
Default Re: (93turbo16)
blah, honestly id be happy with 350...
Old Jan 25, 2007 | 03:32 PM
jarvis199's Avatar
Default Re: (jarvis199)
wonder waht the pump gas limits are on this thing??? i was thinking about on the next dyno trip bumping it to 25psi and tuning it as safe as possible, low timing and see if i can hit 350 with it...
this is my daily driver tho lol, i guess i should be careful!
Old Jan 25, 2007 | 03:51 PM
Jason703Racing's Avatar
make sure to do springs/retainers at least before throwing alot of boost on old parts.. but a 16g can flow to 350hp-400 tops.
Old Jan 31, 2007 | 10:00 PM
jarvis199's Avatar
Default Re: hahn 16g on d16z6 (Black00em1)
not to bring up an old thread, but i dynoed this hahn 16g today @ 295whp 255tq @17psi...
so i think this turbo will do for a while...
http://i33.photobucket.com/alb...3.jpg
Old Jan 31, 2007 | 10:20 PM
sohc_turd's Avatar
nice job! are you still using that HM top mount? or am i thinking of someone else?
Old Feb 1, 2007 | 06:26 AM
jarvis199's Avatar
Default Re: hahn 16g on d16z6 (sohc_turd)
thats me, its not a top mount, its just a little equal length thing i did, not pretty, but seems to work good!!!!
hoping to go back in a few weeks, open cutout, 20psi, 59300 camshaft and edelbrock manifold... hoping for 350 from all that, not sure how thatll work out tho...
Old Feb 1, 2007 | 09:08 AM
sohc_turd's Avatar
I think you should be able to hit somewhere in the range of 350whp... Just make sure to bring some race gas and 25psi for insurance.
Old Feb 1, 2007 | 09:56 AM
jarvis199's Avatar
oh the next dyno day will be me with 25psi, open downpipe and a full tank of racegas
godfatheracing
Oct 19, 2012 06:20 PM
ieatpaint315
Jun 29, 2007 05:21 PM
eddyboy
Mar 27, 2005 07:39 PM
sleeperx
32
Mar 11, 2004 10:53 PM
MyWhiteCivic
Aug 13, 2002 09:44 AM
