GT4088r setup
Old Jan 9, 2009 | 06:10 PM
JLHDOHC's Avatar
Default GT4088r setup
Ok recently finished a gsr build having serious problems on power and tq. I have a 84.5mm sleeved block forged internals endyn oil pump and mild ported head stainless valves and dual springs titanium retainers arp head stunds and mains edlebrock manifold 76mm throttle body full-race top mount twin 44mm waste gates gt4088r with a 1.06 turbine. Last year i had the same setup with gsr cams this year i put skunk2 pro 1 cams in it boost is been 10 to 15psi havent boosted it hard should i be with this turbo to acheive the hp goals I want its been between 300hp 287lbs a tq on 12psi with the pro 1s and 375hp 300tq on 12psi with gsr cams also on 15psi i made 420hp 330tq so I guess i lost power running the pro 1s any ideas what i might need to do not trying to be a dumb*** kinda was working my way up on boost i know this thing can handle the boost i no i might need a tunner all tunning on pump 92 gas
Old Jan 9, 2009 | 08:36 PM
hybrdthry911's Avatar
Default Re: GT4088r setup
do you have a dyno graph, makes it a lot easier to analyze with the graph. maybe vtec isnt engaging. 300ftlbs and not making more than 375whp means you arent carrying that torque much past 6500rpms. what are you spinning the motor to?
Old Jan 10, 2009 | 07:02 PM
JLHDOHC's Avatar
8000 rpms since I put those skunk2 cams in I haven't heard vtec engaging dont have a dyno gragh its a slow pull but not much of a jump were vtec would be I thought it might be the cams elemenated that cross over and sound after 8000rpms it falls off
Old Jan 12, 2009 | 08:12 PM
JLHDOHC's Avatar
do u still get the engaging feelling of vtec with those pro 1 cams or no because of the lobe seperation
T9U4ReBgO
Jan 21, 2010 05:22 AM
JLHDOHC
Nov 2, 2007 04:07 AM
B18C_EJ8
Oct 29, 2007 04:35 PM
Fatty_1775
Aug 9, 2006 07:42 PM
MikeySpec
Dec 28, 2003 11:04 PM
